What do you guys use to push them back in there and get the caps started back on? I was thinking of changing the oil in my forks for some heavier oil and was wonderinfg if a fluid extractor would work versus removing the fork tube and inverting?
TY FXD2003Rider, I'm not at home right now because I am working out of state but I will order a 1 3/8 cap nut socket and when I use it I will let you know if it worked.
Just got in from doing the front springs and a 1 3/8 worked fine
lol Why do you have to order it? Just go to Auto-zone. They have them in stock. That's where I got mine.
Well you don't need to laugh. Do they have the ones with the rubber o ring to protect the chrome? Thank you.
Sorry, didn't mean to insult you. It did make me laugh a little though. It's all good.
Originally Posted by gphil12873
Just use some blue painters tape....
Gphil...you took the words right out of my mouth.
[edit] I did cut mine down so that inside of the socket was between 1/4" and 1/2" deep. I found the taller socket made for some interesting flights if it got away from you during reinstallation.
While lots of people have used a 35mm socket, I believe the nut is actually 1-3/8" but has the rounded corners. A 6-point 1-3/8" socket seemse to work. 35mm is 1.378" and a 1-3/8" socket is 1.375", so the difference is small. That difference does accommodate tape to preserve the finish.
Either size will work.
One thing you have to take into account is the fact that the front ends are japanese, made by Showa. Japan does not use SAE. They are metric, so the 35mm size is more than likely the correct size to use.
Also, remember the fork size is measured in mm, 49mm for late models. 49mm = 1.93in.
