fatbob doesnt idle down sometimes
Old Mar 23, 2010 | 11:54 PM
BrassHOLE's Avatar
BrassHOLE
Default fatbob doesnt idle down sometimes
my bros fatbob has a lil issue where youll ride it and everything will be fine then youll come to a stop light and its like it stuck on some high idle. any one have any ideas. it has v&h pipe and a powercommander
Old Mar 24, 2010 | 12:02 AM
mikel61101's Avatar
mikel61101
Tell him to let off the throttle...lol j/k ask him if he uses the adjuster screw under the throttle side housing... I use that for a makeshift cruise control and occasionally will forget to loosen it and the throttle won't back all the way off...
Old Mar 24, 2010 | 12:04 AM
BrassHOLE's Avatar
BrassHOLE
no he never uses that and it seems may be like a ecu issue or a aire leak may be somewhere just really curious if anyone else has have the same issue
Old Mar 24, 2010 | 01:35 AM
Ratbob's Avatar
Ratbob
Tell your buddy to connect the Power Commander to a computer and run the utility to calibrate the throttle position (Hold down CTRL and press T).
Old Mar 24, 2010 | 01:48 AM
Bob'n'Stang's Avatar
Bob'n'Stang
I had the same issue. It could be in the map he's using. The map that I run had 5% added to the 0% line at 750 and 1000 RPM's. I took that 5% out and no more problem.
RickK
Mar 1, 2014 06:08 PM
elbohead
Jun 11, 2013 10:13 PM
triked
11
Apr 14, 2010 03:33 PM
johnebb
May 13, 2009 06:52 AM
Jessie
May 9, 2009 10:50 PM
