Lining up heat shield tips
Old Mar 24, 2010 | 12:33 PM
Livnoutdoorsxd9's Avatar
Livnoutdoorsxd9
Default Lining up heat shield tips
I put on my VnH big radius 2-1 pipes, but im having trouble getting the heat shields to line up and say lined up. I got them pretty well matched up, but after a little riding, they separated about 1/4" i tried tightening down the clamps more but they still seem to move. any suggestions?
-Livn
Old Mar 24, 2010 | 12:37 PM
bakerm75's Avatar
bakerm75
I had the best luck by first putting everything in loose. then slowly tightening and retightening till I got it where I wanted.
In the process I found I needed a 1/4 " spacer that wasn't included to make them come together right.
Every Bike is a little different. it took me 6 hours of playing to get it right.
Old Mar 24, 2010 | 12:48 PM
rounder's Avatar
rounder
-Livn
yeah, spray wd-40 on the clamp area. You'll find you can tighten the clamps up an extra 1/2 turn or so. Also tighten the clamp with a socket instead of a screwdriver. The clamps cam bind and when you think they are tight with a screwdriver, well, they are not.
Old Mar 24, 2010 | 04:30 PM
Livnoutdoorsxd9
Ive been using a socket, but ill give the wd-40 a try. thanks!
-Livn
balloo
Sep 5, 2014 08:23 PM
Grendel4
May 12, 2010 03:54 PM
maddghost
Aug 21, 2008 06:44 PM
quigley
Exhaust System Topics
Feb 9, 2008 09:58 PM
relli
May 28, 2007 05:16 PM
