Baffles
Old Mar 24, 2010 | 02:32 PM
bikecop40's Avatar
bikecop40
Default Baffles
Is anyone out there running without baffles, Thinking of removing the baffles from my SE slipons after hearing a similar setup on another bike. Isn't there supposed to be some kind of back pressure????????? the guy that had the bike said you don't want any back pressure ( the sound was fantastic though.
thanks for the input
D/C
Old Mar 24, 2010 | 02:43 PM
blackmopar's Avatar
blackmopar
there needs to be backpressure - just how much depends on the flow of your exhaust - im not familiar with your slip ons, but my 2:1 sounds like **** without baffle AND even without packing - and in fact a dramatic change in performance with or without packing also.
Old Mar 24, 2010 | 02:46 PM
Sash302's Avatar
Sash302
I am running v&h BBs without buffles and bike runs great and sounds great to
Old Mar 24, 2010 | 03:17 PM
J-RoX's Avatar
J-RoX
i am running V&H Short Shots w/o baffles .... sounds mean, lost very little on low end.
VERY little.
Old Mar 24, 2010 | 04:49 PM
bakerm75's Avatar
bakerm75
There are hundreds of posts on here for baffel questions.
I believe if you go through the under 50 post above you can find one on the SE slip ons, on removing or changing the baffles.
Old Mar 24, 2010 | 06:10 PM
Lorance66's Avatar
Lorance66
I took the baffles out of my Big Radius 2-2's and not only did it sound like a big bag of dammit, ALL the torque was gone. That was my case and obviously with different exhaust.
Old Mar 24, 2010 | 07:18 PM
Nevar's Avatar
Nevar
07 FXDWG with BSS useing Lolly-Pops
Great sound, not HP loss
Old Mar 24, 2010 | 08:09 PM
SuperFastGlide's Avatar
SuperFastGlide
throw some BCT monster baffles in those babies and have the best of both worlds
Old Mar 24, 2010 | 08:20 PM
cuppy's Avatar
cuppy
Buying quiet baffles this week. True duels, Boy is this thing bad.
Old Mar 24, 2010 | 08:33 PM
HDDyna2006's Avatar
HDDyna2006
I tried lollypop set up using eyebolts with 2 washers thru eye hold by small screw w/ nut, ran eyebolt thru hole for screw that hold baffle, hold in place with 2 nuts. lost some back pressure, sounded loud, kept glasspack inside mufflers.
Or just open SEII flaps inside baffles.
