Heeeelllllllllllllpppppppppp
Old Mar 28, 2010 | 06:27 PM
Livnoutdoorsxd9's Avatar
Livnoutdoorsxd9
That step onlt slips your mind once, managed to fix mine with a small allen head screw, but inconvenient none the less...
Do not remove or install the master cylinder assembly
without first positioning a 5/32-inch (4 mm) thick insert
between the brake lever and lever bracket. Removing or
installing the master cylinder assembly without the insert
in place may result in damage to the rubber boot and
plunger on the front stoplight switch. (00324a)
-Livn
Philly1200
Sep 14, 2014 09:21 PM
junglejoe
EVO
Jun 18, 2013 07:23 AM
larsfum
EVO
Feb 28, 2013 04:43 PM
jon0808
Mar 2, 2008 07:39 PM
skipit
Jun 11, 2007 02:53 PM
