BDL Belt Drive - Installed on a Dyna
Don't confuse the narrow enclosed primary of the Sturgis Shovel with the 3 inch open primary's of today. They are virtually indestructible, and short of a rock puncture, will last forever. They are basically pirated from the Fuel bikes running the drag strips, and can withstand triple the horsepower that ANY street Harley could throw at it. But they are not enclosed, nor do they resemble anything stock. I have run MANY open belt primary's in the past, but never enclosed like SURFORCHOP. If I was spending the money for a belt driven primary, I wanted to see that sucker spinning around and making noise, not hidden and enclosed in a primary!
I have seen SURFORCHOPS bike up close. He vented his setup, and yes, he did the enclosed primary because they are light weight, and eliminate the oil bath chain. I have not seen him post in a while, but I would love to hear an update of how his setup is working now a days.
Here's a clip of the dual belt Sturgis:
The clutch plates are compatible with HD standard.
I couldn't ask for a more reliable primary drive.
I went through a few belts well before the expected life ... at first I thought it was an issue with alignment ... got that kink worked out ... then, a guy at the parts store who I showed my belt to said it looked like the wear was heat related ...
So, I did a little self-help venting of the primary cover ...
You still got your old Evo Low Rider? ... saw you added a Fat Boy to the stable and now a 110th Ann. Road King ... I like what you've done with it ...
Happy Turkey Day!
R/
'Chop
