BDL Belt Drive - Installed on a Dyna
Old Nov 28, 2013 | 02:49 PM
  #31
bikerlaw's Avatar
bikerlaw
Naw, sold them. Just have the Road King, the Sporty and the Wifes VSTAR. But that things for sale. All she cares about is the Sportster! She rode the Yamaha once since we got that Sporty.
Old Nov 28, 2013 | 03:05 PM
  #32
128auto's Avatar
128auto
It is unique now, never seen that before.
Originally Posted by SURFOR Chop
A little update for the curious ...
So, I did a little self-help venting of the primary cover ...
Old Jul 5, 2014 | 07:30 PM
  #33
tonymontanna1983's Avatar
tonymontanna1983
Is this setup still performing well?
Old Nov 2, 2015 | 05:33 PM
  #34
FurryOne's Avatar
FurryOne
After riding around some this afternoon, I am kind of wondering ... does the compensator sprocket have that much of an impact on the ride quality ...? Seems now a lot of vibration is being transmitted to the bike ... after kind of puzzling over it for a while I am assuming it is due to the vibrations being sent up through the drivetrain to the chassis ... mostly only occurs at lower RPM--right after upshifting (guestimating around 1,800 - 2,500 RPM) ....
Without the compensator you'll feel every power pulse through the frame. A general misnomer is that the belt will absorb these shocks, but the belt is made of kevlar and doesn't stretch/give. You'll get used to more vibration over time. The BDL units actually lower your RPM's a slight bit, while the R-P units increase your RPM's a bit. I've had the Rivera-Primo 3" open belt on my FXSB for about 6K miles now. The only problem I had was that I didn't replace the stator seal and found that HD had installed a nicked seal that was leaking - had to pull the inner primary off again and install a new, reversed seal.
Originally Posted by atlantaallen
I would understand doing this if it were in fact quieter and/or smoother, but the OP is saying there is more vibes instead of less. Guess I don't understand cost/ benefit ratio to this one. Nonetheless good post and thanks for the info.
It IS quieter, but if you go to an open primary you can hear the clutch plates rattle around, especially in neutral. On the enclosed belt systems like the OP's that shouldn't be a problem. It also eliminates pretty much all the "clunk" when shifting into 1st at a light. The main advantage is that a correctly setup belt doesn't need adjustment and a tensioner. It doesn't stretch (kevlar) so it comes set up correctly from the Mfr. - it's one less thing to check all the time.
Chopper Nate
Nov 29, 2014 11:39 PM
berndog
Shovelhead
Apr 13, 2012 08:53 PM
sly_buck
Sep 26, 2011 07:01 PM
waynemags
Custom Models
Jun 14, 2010 04:57 PM
Eyespy
Oct 2, 2006 01:11 PM
