Tail light question
Old Apr 2, 2010 | 08:28 AM
dog116929's Avatar
dog116929
Question Tail light question
Recently purchased a 2004 Wide Glide that had the rear turn signals removed. I purchased a kit from HD that had two sets of turn signals, both front and rear. The rear lights are two wire single filament, and the front are three wire double filament. I would like to have the rear turn signals serve as both running lights and turn signals. Can I install the front signals on the rear and have both running and turn signals. I have the service manual along with the wiring diagram but unsure where I would connect the third wire in the rear tail light housing, would I splice into a wire going into the tail light. Would I be better off buying more stuff from HD and get the wiring kit that turns the rear turn signals into, running, turn , and stop.
Old Apr 2, 2010 | 08:50 AM
SC-Longhair's Avatar
SC-Longhair
Cheaper to just buy the run/stop/turn module and install the proper rear signals.
Old Apr 2, 2010 | 12:40 PM
dog116929's Avatar
dog116929
Thumbs up
I believe I will take that advice.
Will install the turn signals as they should be, run for a few days, then get the Turn, run, stop thing.
Thanks
Old Apr 2, 2010 | 02:27 PM
mikeault's Avatar
mikeault
Dog, I sent you a PM. I have an extra one.
Old Apr 2, 2010 | 02:39 PM
8541hog's Avatar
8541hog
Yes you can easily do that, no need for any module if you have 3-wire signals.
You should have a black, a brown or violet, and a blue wire on the lights correct?
Black is ground, blue is tail, and the brown or violet are turn.
Do you want all 3 on each light or do you want run and turn, or stop and turn?
Old Apr 2, 2010 | 04:17 PM
Pirate Boy's Avatar
Pirate Boy
+1 on the run turn brake, I just put one on and WOW what a difference in lighting it makes. I bought the kuryakan model i wanted the pulse brake light also
Ride Safe
Pirate
jackalsilva
Electrical/Lighting/Alarm
Jun 21, 2016 04:23 PM
Bighec
Jan 25, 2015 09:31 PM
Mikula
Jun 15, 2014 02:38 PM
1999 Wide Glide
Apr 4, 2014 08:07 AM
jdvorchak
Jan 9, 2009 02:00 PM
