Any Dyna Lowrider with a Windvest?
Old Apr 12, 2010 | 11:21 AM
TN-Triker's Avatar
TN-Triker
Default Any Dyna Lowrider with a Windvest?
Okay, I've searched the threads looking already..Couldn't find anyone with a Windvest on their Dyna Lowrider. My Dyna is a 2009 stock lowrider. I just bought a used Windvest that was on a 2006 soft tail. The mounting brackets are too small (1 1/4). My husband used a caliper and the forks measure 1 3/8. Windvest Mfg. says they don't make that size. What size are your forks and what size are your mounting brackets? Help...I might have to return this windvest!!!!
Old Apr 12, 2010 | 11:49 AM
thedonthere's Avatar
thedonthere
your forks are 49mm they make stuff for your bike
Old Apr 12, 2010 | 11:51 AM
maduxfn31's Avatar
maduxfn31
I had a Windvest on my Wide Glide when I bought it and it attached to the handlebars but I didnt like it so I went with a full sheild
Old Apr 12, 2010 | 11:53 AM
red69camaro's Avatar
red69camaro
Mine mount to the bars
Old Apr 12, 2010 | 12:07 PM
the reverend's Avatar
the reverend
Old Apr 12, 2010 | 12:17 PM
doublenaughtspy's Avatar
doublenaughtspy
I'm pretty sure they go on the bars, not the forks. At least it's that way for my wide glide...
Old Apr 12, 2010 | 01:33 PM
OldMike's Avatar
OldMike
I just got a Windvest, mine mounts on the handlebar.
Old Apr 12, 2010 | 01:57 PM
TN-Triker's Avatar
TN-Triker
I meant to say risers...I know you don't know what I meant to say just what I said..with that out of the way. There is no way that this windvest will attach to my handlebars, unless a part is missing. If the clap was larger it would fit my risers. This windvest came off an 03 Soft tail with buffalo Tbars (I think that is what she said) and yes it fit on her handlebars. Is there anywhere I can look to see what the mounting system looks like. How many pieces does it have. I have a cross bar and clamps. That is it. When I put the clamps on the crossbar, they do not swivel, so they will not fit on the handlebars. I am going nuts...this cannot be.
Old Apr 12, 2010 | 01:59 PM
yandeltx's Avatar
yandeltx
Default windvest
I have a windvest that mounts directly to my 1 1/4 apes.
Old Apr 12, 2010 | 04:30 PM
bberck's Avatar
bberck
You can buy some 1 1/2 inch mounts and put some rubber on the inside to make them fit snug. I did this with the windvest I bought. It came with the 1 1/2 mounts and I had it installed on my 1 1/4 bars. The rubber also protected the bars from getting scratched as well.
Another option is to replace your risers with 1 1/4 risers (maybe cheaper as the Windvest mounts are high) or buy some 1 1/4 Spacers from spacer Jim and raise your bars a little and mount it to the spacers.
