turn signal relocation
They are a pita to move , But, IMO the look way better. Hope this helps.. i'll go out and get some better photo'sKinda looks like a goofy bug or something. I think the hardest part of the whole install was the factory plug
pin removal, PAIN in the butt!
I bought the relocation kit , and cut down the moco stalks.
I was thinking that the HD ones could be chopped, no reason not to do it now. Mine are on the bike at the moment.
Any suggestions or tips on doing this mod?
Could you post a few close-up pics?
http://www.customcycleengineering.co...ex&cPath=84_88
What i done was taped them up. with masking tape , made a cut out in the shape of the bullets with card board and transfered the image. Then I cut with a dremel tool to roughly the cured shape needed. i took a 1/4 " barrell drum sanding bit and coped out slowly the in side to acommidate the bullet,
To make a support for the bolt to mount, i bought 2 1 1/2 x 5/16 fine thread grade 8 allen head bolts at the hardware store..
The inside being tapered i took 2 5/16's washers , one for each , and dremeled them to the shape to accomidate, the bolt centered the bullets on the mounts, sealed the small gaps with clear rtv rewired with heat shrink and done deal. Yea , i guess i could spent more money on different mounts, But , i'm a cheap F*&k , and not afraid to try and work it out first, not hard at all , take your time , My buds like em but to lazy to try it.. good luck.. (WTF was the MoCo, thinkin with those long stalks anyway?)
