**Screaming Eagle Compensator**
Old Sep 13, 2012 | 10:50 AM
  #51
soft 02's Avatar
soft 02
Originally Posted by 07bobber
whats the improvement over the stock sprocket?
Weight, spring pressure and travel.
Old Sep 13, 2012 | 11:04 AM
  #52
jward's Avatar
jward
Clutch action when shifting especially from standing start....things seem quieter and smoother
Old Sep 13, 2012 | 12:10 PM
  #53
soft 02's Avatar
soft 02
Guess I was a tad literal...
Old Jun 5, 2013 | 08:29 AM
  #54
tennesseeguy's Avatar
tennesseeguy
I am installing the screaming eagle compensator today and a quick question? The threads are left hand threads correct? I mean it takes a 13/16 inch socket and to loosen I turn counterclockwise if I am thinking about it right? I seem to have a little play either way I try to turn it and not sure that is normal? I don't want to break anything so thought I better ask..thanks.
Old Jun 5, 2013 | 08:57 AM
  #55
soft 02's Avatar
soft 02
on your 07 the compensator is right handed while your clutch is left handed.
Old Jun 23, 2013 | 01:12 AM
  #56
07bobber's Avatar
07bobber
thinking about getting the se comp.
heard about some issues with it in the touring section but haven't really researched it.
Old Jun 23, 2013 | 01:36 AM
  #57
srt8's Avatar
srt8
subscribe for reference later, thank you for write up
Old Jun 23, 2013 | 01:01 PM
  #58
Panimal's Avatar
Panimal
Sorry if this has been answered before, I didn't see it, but is there a smaller front engine sprocket to fit on a 2012 Dyna? I would assume if there is, I'd need a shorter chain too. Anyone have info or a link for a smaller front sprocket?
Old Jun 23, 2013 | 01:20 PM
  #59
maddghost's Avatar
maddghost
your stock sprocket is 32 teeth, Andrews makes a pulley for dyna's that is 30 teeth no chain or belt change involved. Alan summers has a very good write up for that mod ;
https://www.hdforums.com/forum/dyna-...y-install.html
Old Jun 23, 2013 | 04:04 PM
  #60
Panimal's Avatar
Panimal
Oh, sorry man... I guess I wasn't clear with what I was asking. I knew about the 30 tooth pulley, but I'm wondering about converting my front compensator sprocket in the primary to a smaller sprocket and possibly shorter chain. That will result in the effect of raising engine RPMs while cruising in 6th gear (or any gear), but not change the final drive pulleys or belt.
WS6 Formula
Pacific
Dec 13, 2011 11:07 PM
20NightTrain03
Northeast
May 8, 2008 08:28 PM
