blown head light fuse
Old Apr 15, 2010 | 03:41 PM
cosper's Avatar
cosper
Default blown head light fuse
before i start pulling wires,,,what are the easy checks? it happened last night as i stated my 09 SB to head home from work. tried a couple of new fuses and as soon as i turn the key, light comes on , then fuse blows.
thanks,
cosper
Old Apr 15, 2010 | 03:48 PM
cosper's Avatar
cosper
also,,,the wife and i are going away this weekend to an over night camp out car and bike show(no night riding). i should have anyhting else electrical to worry about , should i. i think its just a pinched or cut wire.
Old Apr 15, 2010 | 04:16 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
A blown fuse -most of the time- indicates to a short-cut. You can use a multi-meter to check this out.
Could be a punctured wire.
Have you been working in the handlebar wiring lately?
If yes, my advise would be to check if the wiring on the left hand side switch housing is running into the dimples of the handlebar...
Otherwise check the if the harness wires in the headlight housing and under the seat are running free.
FXD2003Rider
Old Apr 15, 2010 | 04:22 PM
blackmopar's Avatar
blackmopar
my guess would be youve rattled a ground wire loose
on second thought I agree with FXDRider - would make more sense to be a short than a ground
Old Apr 15, 2010 | 04:58 PM
cosper's Avatar
cosper
new bars were put on about 6 months ago. i had pinched wire issues then, fixed them, and had no issues until now
Old Apr 15, 2010 | 05:14 PM
blackmopar's Avatar
blackmopar
whatd ya do to fix? maybe that repair failed due to vibes ro somethign? Be the first place id check
Old Apr 15, 2010 | 06:15 PM
CRZYLGZZ's Avatar
CRZYLGZZ
The Ground wire for the Head lights are located right off the rear portion of the fork.
Here is a pic of mine.
Now Mind you, that line isnt directly affixed to the headlight, but its a frame to handle bar ground and if this one is cut, torn or messed up, that will cause shorts.
Old Apr 15, 2010 | 08:37 PM
cosper's Avatar
cosper
thanks
Old Apr 15, 2010 | 08:41 PM
Lorance66's Avatar
Lorance66
I have often seen bulb filaments kinda melt and fuse together. Might sound crazy but see if your hi and low beam filaments are touching.
Old Apr 15, 2010 | 08:45 PM
streetbobkid's Avatar
streetbobkid
i know when checking some stuff for my brake lights i caused a short and it blew out my fuse, the headlight and tail light no longer worked, checking the tail light wiring might not be a bad idea either, if there is a short on the tail light it will cause the headlight fuse to blow
