06 Dyna Bottoming Out
Old Aug 10, 2006 | 10:44 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: 06 Dyna Bottoming Out
I had the same issue........set them on 3 and no more bottom out issue. My $.02.
ORIGINAL: MaineHD
yes, they are set soft, but if you set them hard then you are sacraficing ride quality on any bump that doesnt cause a bottoming out as you arent using the suspensions full range of movement. Just wonding if people w/ 11" shocks have had damage?
Old Aug 10, 2006 | 10:53 PM
Ouiser's Avatar
Ouiser
It appears the wide glide does not have preload or any other shock settings for that matter. Looks like I'll be upgrading my shocks sooner than I expected.
Old Aug 10, 2006 | 10:55 PM
but Ill try 2 try's Avatar
but Ill try 2 try
ORIGINAL: czissman
"ride quality" is subjective. The purpose of a shock / spring is to keep the rider stable and keep the rubber in constant contact with the road while bringing everything as quickly as possible back to equillibrium. When the suspension is set too soft you may well pass comfortably over surface defects, but your tire will likely suffer at least a reduction in traction during the trade-off: not a good thing if this happens in an aggressive turn. I prefer to sacrifice a bit of comfort in order to keep my rubber firmly stuck to the tar. To me, it feels good to "feel" the road, and thus--to me--ride quality = moderately stiff suspension.
This is true. I think the above post is more car related though. czissman's words are definitely true when your talking about how the four wheels and corresponding shocks on a car are going up and down independently over bumps. With a bike there are no other wheels back there to support the vehicles weight if the rear tire leaves the ground. I just think softy, less stiff shocks are not so bad with bikes. Only reason I'm even trying to discuss this is because I'm planning a long interstate ride in a couple months and I want to know if it'll be with the stockers or the 11" 412s.
Old Aug 11, 2006 | 11:39 AM
nidan's Avatar
nidan
I'd suggest A) go to SE Heavy Fork oil , it helps alot B) Spring for a set of Progressives , they are well worth it. Both worked wonders for me
Old Aug 11, 2006 | 01:38 PM
WS6 Formula's Avatar
WS6 Formula
I used to have that problem, now I just avoid the bad roads and always keep an eye out for pot holes.
scenedirector
Dec 31, 2014 12:32 PM
jjwin98
Jun 21, 2011 08:22 AM
chuckw2
Jul 9, 2010 01:41 PM
pearlandhd
Nov 3, 2009 07:51 PM
GlassBikerNC
May 7, 2007 07:02 PM
