Problems since stage 1 ...HELP!!!!
Old Apr 24, 2010 | 12:24 PM
The Ground Truth's Avatar
The Ground Truth
Thanks any Pig, fuelmoto should be able to get me running right. I still don't know why the light is check engine light is on though. I wonder if its because the stock air cleaner sensor is zip tied now and isn't connected to anything.
Old Apr 24, 2010 | 02:58 PM
FLYSBY's Avatar
FLYSBY
As far as I know, there were only 2 O2 sensors and one was in front - near lower part of forks - and one under the seat. We never disconnected anything behind the air cleaner - although we did zip tie an auxilliary connection from behind air cleaner.
I also have the fuelmoto setup. Never had any check engine lights on. Maybe you should start at square one and redo the efi setup. It was real easy to put on so it can't take more than a few minutes and the peace of mind would be worth it. Try taking it off and see if check engine light is still on. That should tell you where to start.
Not a mechanic, I just play one on TV
Old Apr 24, 2010 | 04:50 PM
nathanw's Avatar
nathanw
Not the first time I've heard of a fuelmoto bike running way too rich and returning horrid gas mileage. Save the map on a laptop and try one of the maps that closely matches your set up, they are available on the PC website. I'd bet anything your mileage would go up without any negative effect to performance. The other option is to get a custom map, but that involves spending a few hundred bucks.
http://www.powercommander.com/powerc...mdl=33&yr=2009
Try map # M15-005-020
or map # M15-005-019
Old Apr 24, 2010 | 11:20 PM
The Ground Truth
Default Culprit found!
After pulling out my PCV I found a connection that was missing. Somehow it must have recently popped off. I plugged it in and my check engine light went off. I'm definitely very relieved that it wasn't anything more serious than that. Now I just need a better map so I can get more that 85 miles to a tank! Here is a pic of the connection, its the one with the white tag on it. Thanks to all who helped me out with the issue.
Old Apr 25, 2010 | 01:49 AM
PigInaBlanket's Avatar
PigInaBlanket
Glad you found the problem. That actually may also fix your gas mileage problem. Let us know if it does.
Old Apr 25, 2010 | 09:10 AM
The Ground Truth
I'll post an update later on this week. Its been raining really bad here so I haven't been able to get out in days.
clap
Jul 2, 2014 11:16 PM
The Ground Truth
Jul 9, 2013 03:39 PM
xtasee78
Sep 11, 2011 06:44 PM
RickyB
Mar 22, 2009 08:28 PM
smokermike
Jun 12, 2006 03:48 AM
