FXDWG docking hardware installation
Old Apr 27, 2010 | 09:26 PM
Chief Razorback's Avatar
Chief Razorback
Question FXDWG docking hardware installation
Any advice from anyone who's installed the docking hardware for rear quick detach including the turn signal stalk change? Isn't there any way to avoid cutting the wires and having to splice under the fender?
Old Apr 27, 2010 | 09:29 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Take off the tail light lens and unplug the signals. Take the connector off the end and snake the wires out and back through. then reassemble.
Old Apr 27, 2010 | 09:31 PM
HDDyna2006's Avatar
HDDyna2006
If you can get wires off the connector, I supposed you could, or maybe both pins won't fit thru hollow screw. i know in my case, I splice and the two wires barely made it thru screw, I had to lube them.
Also make sure you have all parts threaded thru wires, specially the tiny plastic cap closer to sigs. Have to pry bullets insides to reroute wires, somebody here designed a wire hook for this.
Old Apr 28, 2010 | 04:38 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by HDDyna2006
...Have to pry bullets insides to reroute wires, somebody here designed a wire hook for this...
At your service....
turn signal socket assembly extraction tool
Old Apr 28, 2010 | 08:07 PM
Chief Razorback
Originally Posted by FXD2003Rider
Worked perfectly!!
A million thanks.
Old May 1, 2010 | 10:38 PM
Chief Razorback
Default finished
Thanks for the info everybody, I finished the sissy bar removal and docking hardware install tonight without any problems (except running out of beer).
Attached Thumbnails FXDWG docking hardware installation-dscf1287.jpg   FXDWG docking hardware installation-dscf1288.jpg   FXDWG docking hardware installation-dscf1290.jpg
W.P.
Apr 17, 2017 12:51 PM
Rebobbed
May 19, 2011 02:36 PM
truthfire
Jan 16, 2011 05:10 PM
Johnny_Ringo
Aug 24, 2010 01:33 PM
DesertDyna
Jun 28, 2010 07:32 PM
