New Risers and Center Console installed
Old May 2, 2010 | 01:47 AM
NoLongerAmember's Avatar
NoLongerAmember
Originally Posted by Wonkaboy
My small write up not much but here it goes , you have to take off the plastic cover thats under the frame above the valve covers and also raise the tank for more room to work , now you have to pull out all the wires from the hole there is one set that goes to the neck it's a tight space but you have to reach and pull the plug thats the harness ( 3 wires ) thats going to plug right into the ignition switch in the console but you have to cut and add about 8 inches to reach it , the hard part is stuffing the wirings back in the hole at the end , there are alot more tech posts on this forum on how to do it with photos use the search option and you will find them , Sorry i'm keeping my old console i always see them on ebay try there ...
I was just curious on how you approached it compared to others. I am going to do this with a stock console. I can't afford the way over priced WG console, but it is really the best way for sure.
Old May 2, 2010 | 01:58 AM
Wonkaboy's Avatar
Wonkaboy
I have seen it done with the SB stock console but don't like how the ignition mount has to be fasten to the console , you have to drill and then have exposed screws on top, the WG console the screws are hidden underneath , but to each is own , good luck with it !
Old May 2, 2010 | 02:07 AM
NoLongerAmember
Some have drilled holes, but you can make a bracket that mounts to the tank and the switch mounts to that. I think it was Walter Windbag who originally did the mod using the stock console and it did come out nice. The problem I see is you can't really get rid of all the ribbing on the stock SB console and I have not seen one done up close, one reason I am looking for a console in case I booger it up.
CB
Here is the original mod.
https://www.hdforums.com/forum/dyna-...treet-bob.html
Old May 2, 2010 | 02:30 AM
Wonkaboy's Avatar
Wonkaboy
CB
I have seen all the write ups before , the wires were enough me to do without getting involved with drilling and lining up everything to much chance for me to make a mistake , I saved the money and had no headaches , nice clean direct bolt on !
Old May 2, 2010 | 09:27 AM
Taddeoeg's Avatar
Taddeoeg
Console looks great, Wonka. I may have missed it, but did you post a list of the part numbers required for this mod? Would love to see that.
Thanks!
Old May 2, 2010 | 10:57 AM
NoLongerAmember
I agree, you definitely went the the right way. I only posted that up because you mentioned drilling the console to mount the switch and seeing the screws, not to mention $200+ is a lot of coin for that console and there is an alternative if one so chooses.
Again, looks great and the way our SBs should have came!
CB
Old May 2, 2010 | 11:38 AM
bunkerbeer's Avatar
bunkerbeer
Nice. Love it.
Old May 2, 2010 | 11:54 AM
rounder's Avatar
rounder
Looks good...did you have the strut covers off before(thought I saw a pic. that way).
Old May 2, 2010 | 03:20 PM
Wonkaboy's Avatar
Wonkaboy
Thanks!
Heres all you need :
1) Console;
Chrome is 61712-08
Black is 61732-10
2)Speedo Gasket (different than Street Bob gasket)
70706-08
3)Ignition Switch
71313-96A
4)Switch bracket
71766-08
5)Self tapping screws (4)
2501A
6)Ignition switch label
71262-05
7)Fork lock decal (minus ignition/accessory icons)
14130-06B
Old May 2, 2010 | 03:22 PM
Wonkaboy's Avatar
Wonkaboy
CB
Watch for the future SB i bet they will come with them sooner or later !
