Lowering the idle speed.
Old Sep 13, 2010 | 10:02 AM
  #41
Wireguided's Avatar
Wireguided
I dropped mine to 920 with a TTS.
But i also raised my oil pressure with the baisley spring just cause i was in there..
Old Nov 12, 2010 | 09:47 PM
  #42
Sash302's Avatar
Sash302
this guys in japan love to idle low those TC96
http://www.youtube.com/watch?v=WVCc9MAHGbI
http://www.youtube.com/watch?v=hTyiD...eature=related
http://www.youtube.com/watch?v=G0GsG...eature=related
Old Nov 12, 2010 | 10:03 PM
  #43
rmatt34's Avatar
rmatt34
Makes me miss my old Evo FXDL...
Old Dec 4, 2010 | 10:04 AM
  #44
eazyride's Avatar
eazyride
I was told not to set the idle lower than 1000rpm, at least 900s. Lower than that the oil can't get pumped up to the top. That goes for carb n injection bikes.
Old Dec 4, 2010 | 02:12 PM
  #45
parts eeter's Avatar
parts eeter
With FuelPak equipped bikes you can add 1 or 2 points at Value 17 and knock the idle down 50-150 RPMs . I wouldnt want to go any lower cuz where I live I have to pull out on a 4 lane and low idle settings tend to try and stall when called upon quickly.
Old Dec 4, 2010 | 06:36 PM
  #46
Wireguided's Avatar
Wireguided
I myself doubt that bob is at 6oo....... mine sounds the same @ 912 after warm up...
The Efi need warm up time to finish and set final idle and AFR .....
Old Dec 21, 2010 | 08:31 PM
  #47
nightranger's Avatar
nightranger
Default throttle stop
Originally Posted by 1tontractor
i was also curious about this cause a buddy of mines 08 nightster lopes a lot lower than my 06 Bob. A few days ago i was looking to lower the idle just a bit and i found what looks to be a mechanical idle adjustment but requires a special security star looking tool.
Currently i have a Stage 1 so i dont have that idle adjustment option, has anyone lowered idle using this mechanical stop???
if you are talking about the screw in the back of you're se air intake i took this all the way off it doesn't change a thing.
Old Dec 21, 2010 | 08:37 PM
  #48
archergodwin's Avatar
archergodwin
Originally Posted by ghostrider69
You won't a low idle? Dump the ECM all together. Don't spend a penny on a Thundermax. Buy an S&S carb kit and a Thunderheart ignition and convert that baby back to the way it should be. CARBED!!
Has nothing to do with the fact the motor is fuel injected... it's oil pressure. Install a high pressure high volume pump and you can probably lower the idle....
however... yeah... it doesn't have quite the 'old lope' sound.... but there's no mistaking what I'm riding...
Old Dec 21, 2010 | 08:48 PM
  #49
editbrain's Avatar
editbrain
Spec calls for 1050 to 950. If set to 1000 you will see it jump 100 RPM +/-. I recently set mine to 920, and I think that I am fine there.
SlimPaul
11
Jul 30, 2015 07:02 AM
Hogster 1
Dec 15, 2012 10:16 AM
radudel
Feb 28, 2012 04:38 PM
danike
Sep 13, 2008 11:58 AM
glock9
14
Jan 22, 2007 05:19 PM
