need imput
Old May 15, 2010 | 07:18 PM
02low's Avatar
02low
Stage I
Default need imput
i have an 02 dyna lowrider....it was runnin fine before it sat for about 4 months....(had child on the way so no time to ride) after i got a battery for it and took it for its first ride the the shifter was sticking and the trans has hung in third and not wanted to shift to fourth....what would cause this
Old May 16, 2010 | 07:01 AM
jmpancoast's Avatar
jmpancoast
Not having a good tech based answer for you, I would suggest making sure clutch is properly adjusted and changing tranny and primary fluids.
Old May 17, 2010 | 05:23 AM
Hooker 6's Avatar
Hooker 6
Check corrosion on the shifting rod. I had a similar problem and the stealer fixed it only temporarily. My problem was build up of corrosion on the rod the shifter rides on and the race it passes through on the case. I removed shifter rod and emery clothed the hell out of both - put emery cloth on a dowel t work the case. Then I loaded it up with white lithium grease, and I have not had another problem.
128auto
May 7, 2013 09:32 PM
leadman
May 25, 2011 11:12 AM
tbone52
Sep 27, 2009 09:14 AM
DanDman
Sep 16, 2008 10:53 AM
Figstr
Sep 3, 2008 05:59 AM
