Low Rider Risers
Old May 20, 2010 | 11:09 AM
Roysride's Avatar
Roysride
I like the idea of raising my bars 2" it seems cheaper than having to go through all that trouble with new bars, cables etc...I measured my riser and it seems with the added 2" spacer my electrical cables may not stretch far enough especially with the handle bars turned to either side. Can someone confirm this either way?
Old May 20, 2010 | 11:13 AM
bberck's Avatar
bberck
You should be able to pull enough slack out of the neck for the wiring to reach.
Old May 20, 2010 | 12:17 PM
danl's Avatar
danl
Originally Posted by BlockHead96
OK, I need splaining here, I'm not the sharpest pencil in the box, but If I raise the bars on the same horizontal plane they sit, how does it effect the pull back?
danl. how much rise on those risers??
Block, 6 1/2" rise and 2" of pullback, plus the natural angle of the Lowrider frontend.
Old May 20, 2010 | 01:19 PM
BlockHead96's Avatar
BlockHead96
Thanks guys I just mat try those 2" risers for **** and giggles, it's ony $50.00. I think I will will try to come up with some measurements on the stock pull back dimensions, then install the risers and remeasure the pull back dimension to see how much I really gain.
5gear
Sep 3, 2017 01:35 PM
AFblacksheep
Mar 26, 2017 12:20 AM
kgschlyer
May 4, 2016 10:09 AM
TWNomad
Jul 23, 2013 10:21 PM
needadyna
May 9, 2006 02:35 PM
