problem starting/idling when wet
Dielectric grease is the cure. One of the members even went so far to put a ziplok baggie around his PC connections as a little extra insurance.
One thing though, is that the WD-40 will dissolve the dielectric grease, works great to clean the connections and all, but I would wipe it off and blow out the fuse block and then use the dielectric grease on all the relays, fuses, the caps on the O2 sensors and the ecm/pcIII connector that is exposed.
You also should only rinse the bike off with low pressure and try not to direct it at the exposed connectors.
I had a similar issue as many have had where the fuse block cover will get moisture/water in behind it and then the fuses/relays get damp, do not dry out and corrode, so even if you live in a dry climate and are careful when you wash it you still should clean all the connections an grease it up. I also pull the cover off and wipe the electrical connection off after washing it.
CB
all you need is a dab,, when you the connectors join, the grease forms a seal that acts as a buffer from the elements .
CB
Old Navy habits.
I wonder if they still do those cards.
