Buying my first Harley
Old May 25, 2010 | 12:40 AM
dnebout's Avatar
dnebout
Default Buying my first Harley
Buying my first Harley tomorrow. It's 08 Fat Bob. I've had many bikes over the years but never a Harley. Any ideas on what I should look for?
Old May 25, 2010 | 12:50 AM
ynots's Avatar
ynots
If its like my FXD the first thing you should look for is a new seat Welcome to HD Forum
Old May 25, 2010 | 01:27 AM
dnebout's Avatar
dnebout
Thanks for the reply and the welcome. I'm looking more for what I should look for before I buy it from the guy. I'll ride it to see if there is any shimmy at around 70MPH and look for any leaks, but can't think of anything else right now.
Old May 25, 2010 | 02:01 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Look for a black one . They're pretty rare as far as I know.
Old May 25, 2010 | 02:07 AM
dnebout's Avatar
dnebout
Thumbs down
Thanks for your wonderfully insightful smart a** comment.
Old May 25, 2010 | 02:47 AM
Centerline's Avatar
Centerline
A little touchy about light-hearted banter. You will need thicker skin around here. With your many previous bikes, you should possess vast knowledge of what to look for on a used bike.
You have chosen well should you complete your purchase of the Fat Bob. The Fat Bob is my first Harley as well, and I have found the stock seat superbly comfortable for several cross-country rides and fine for just everyday riding.
I would'nt expect anybody to want to spend much time as a pax on the rear perch of the stock seat however.
If you test the bike and are looking for a shimmy, it is easy to find and your mentioned speed (70mph) is guaranteed to get you a bit of a shimmy even if everything is up to spec (tires, alignment, etc)...... all you ned to do is lean the bike WELL OVER for a sweeping curve at above 60 mph and you will find the back end doing its own thing..... transmitting a feeling to you of being on humongous wandering freeway rain grooves. At speeds under 60 mph, if all is up to spec you can crank that beast WAY on over and it will track tight corners if on rails.
Mine is raised a little over an inch and corners very well in full lean at less than 60 mph.
Love the Fat Bob, a superbly capable canyon carver....for a big cruiser
Old May 25, 2010 | 04:01 AM
96 Wide Glide's Avatar
96 Wide Glide
Just look at the things you would on any other used motorcycle.
There's nothing magical about them! There a motorcycle!
Old May 25, 2010 | 04:05 AM
96 Wide Glide
oh, dont buy a bike off a dude named Centerline....... LMAO!!!
Old May 25, 2010 | 06:27 AM
hamiltonj2w1's Avatar
hamiltonj2w1
I know in the past the earlier bobs had some neck bearing problems I had read about on another forum.
Old May 25, 2010 | 08:22 AM
NOZEM's Avatar
NOZEM
Welcome to the forum. Just look out for cages because they won't look out for you!!!
