Any Advice?
Old May 27, 2010 | 11:35 AM
paul s's Avatar
paul s
Carbon buildup can raise your compression to the point of pinging under a load.
Old May 27, 2010 | 11:51 AM
trip20's Avatar
trip20
Originally Posted by lowrider20000
<snip>... i was in 6th gear...<snip>
What speed in 6th gear??? Hope you were at least doing 70mph...
Old May 27, 2010 | 12:20 PM
grbrown's Avatar
grbrown
Talking
Originally Posted by Grendel4
You have 95 Octane available in the UK? Kewl. I don't think I've seen that high of an octane rating since Sunoco 260 went out of style. Maybe AvGas, but I ain't puttin' that in my Harley.
We have 98 available! But I vaguely recall we use a different octane rating system to the US. The rest of the world often does things different to.....
Old May 27, 2010 | 12:33 PM
Grendel4's Avatar
Grendel4
Like...... Drink their beer cold?
Old May 27, 2010 | 01:13 PM
lo-rider's Avatar
lo-rider
Default you're lugging it!
the hill wasnt a tall incline just a steady up, and ive gone up that how many times, and i was in 6th gear and never had issue like that, ive gone up steeper than this one in 6th, and never had an issue, i just roll back the throttle and up she goes...
You are lugging it!
Unless you don't mind making expensive repairs, learn new riding technique. 6th gear is an overdrive; on my '09 Dyna it is useful for level interstate speeds above 65MPH.
Old May 27, 2010 | 01:23 PM
NoLongerAmember's Avatar
NoLongerAmember
Check the wiring harness for the rear injector, both for that matter. The wires get stressed and break causing an intermittent open. You said you were climbing a hill which could be pulling on the wire so if the injector is not firing it could lean out that cylinder causing a ping or lugging the engine because the cylinder isn't firing at all and then turning with the power coming back makes me think the wire may have come back in contact.
CB
Old May 27, 2010 | 01:31 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 on the lugging...no 6th gear under 65mph. You should be cruising at NO LESS than 2300 rpm. I usually cruise at 2500-2800 which is the sweet spot for my TC88. At 2500 rpm in 6th gear I am at 70mph and at that speed any incline requires 5th gear.
PAULB43
11
Jun 19, 2013 10:16 PM
ALR24
May 6, 2013 08:31 PM
murphyslaw1978
Jul 15, 2008 04:40 PM
MMH
May 25, 2007 06:37 PM
Headwolf
Jun 17, 2006 07:53 PM
