Error code
Old Jun 1, 2010 | 11:45 AM
pugs's Avatar
pugs
Question Error code
I was getting on the bike after work the other day. Put the key in, turned on and pushed the start button. Nothing. No noise from the EFI, couldn't start the engine (wouldn't even chug). The computer display said "bus err." I turned the key off and tried again and the same thing happened. Off and on again and it worked without any problem and the code was gone. I tried to look up the code in the owner's manual but couldn't find it. Anyone have insight on this? Thanks in advance.
Old Jun 1, 2010 | 11:47 AM
SC-Longhair's Avatar
SC-Longhair
If you do a search, there is a thread somewhere that lists all the error codes and how to clear/fix them.
Here:https://www.hdforums.com/forum/dyna-...lear-them.html
Old Jun 1, 2010 | 01:48 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Could be a loose/wet connection. I'd pull all the biggies behind the side-covers, shoot 'em with some contact cleaner or Cramoline, and re-seat them.
Old Jun 1, 2010 | 07:43 PM
pugs's Avatar
pugs
Thanks for the info. I haven't had a chance to look again.
Old Jun 2, 2010 | 07:14 PM
bqualls's Avatar
bqualls
[quote=pugs;6796534The computer display said "bus err." I turned the key off and tried again and the same thing happened. Off and on again and it worked without any problem and the code was gone. I tried to look up the code in the owner's manual but couldn't find it. Anyone have insight on this? Thanks in advance.[/quote]
I checked my 2009 Dyna Electrical Diagnostic Manual. BUS ER troubleshooting is found on pages 4-33 through 4-37. You might want to get the manual for your bike and troubleshoot it or take the bike to a dealer for troubleshooting. The flowchart indicates several potential problems, from short to ground or short to voltage to faulty speedometer or tachometer (if equipped).
Old Jun 2, 2010 | 08:03 PM
pugs's Avatar
pugs
thanks bqualls. i will check into the manual.
calvinbabb
Apr 7, 2019 06:55 AM
Aslow
May 14, 2011 10:47 AM
Smug
Mar 6, 2010 10:43 AM
Bsheger
May 6, 2009 05:59 AM
KeithB
11
Nov 2, 2006 09:23 PM
