will 94 tach work on a 2006 dyna???
Old Aug 20, 2006 | 02:04 AM
dxrich's Avatar
dxrich
Default will 94 tach work on a 2006 dyna???
can a tachometer from a 94 dyna be made to work on a 2006 Dyna Superglide???? c'mon all you gearheads....help !!!
Old Aug 20, 2006 | 12:54 PM
dxrich's Avatar
dxrich
Default RE: will 94 tach work on a 2006 dyna???
anybody got any info on this???
Old Aug 20, 2006 | 02:45 PM
Gulfstream's Avatar
Gulfstream
I don't have a definitive answer but my guess would be no. In 2004 they switched to a serial data bus while the earlier models were straight analog, I doubt they would "talk" to each other. Could it be made to work by hobbling in some new wires....maybe?
Old Aug 20, 2006 | 10:17 PM
DGlide04's Avatar
DGlide04
Gulfstream is right, begining in 2004 the whole connection for the tach changed. HD used to have a pink tach wire that picked up the signal off of the coil. It's been a topic of a lot of discussion here and other other forums, just try doing a search under tach installation and you'll see what I mean. I originally purchased an Arlen Ness tach, nice and compact and matched the color of the bike . After trying every which way from Sunday to install it and talking to at least 3 different dealership techies, I gave up and bought a HD factory tach which worked from the day I plugged it in.
Good Luck.
Old Aug 20, 2006 | 11:27 PM
kpreese's Avatar
kpreese
You can get a suitable signal, however it isn't documented. The 3rd pin on SOME of the newer serial data bus bikes does have a tach signal. I tried this first on my Street Bob with no luck. The 3rd pin on the ECM DOES work though. I would presume this would work with non-HD tachs, but I did this with an HD mini-tach and it works great.
The following link is to a project site where I documented it. I rewired it later because I short-cutted the wire routing originally, but this should still help you figure out the tach signal part and help you decide if you want to give it a shot.
Mini-tach project
Kevin
Old Aug 20, 2006 | 11:37 PM
kpreese's Avatar
kpreese
I meant to add: I don't know if this tach signal is the same as a '94 tach would be expecting. But it definitely gives you some tach options.
Be sure to post if you try this to let us know how it goes.
Kevin
Old Aug 21, 2006 | 01:35 AM
NEONNIGHT34609's Avatar
NEONNIGHT34609
scotch locks .. they should be outlawed . nothing but problems over time
Old Aug 21, 2006 | 01:01 PM
kpreese's Avatar
kpreese
ORIGINAL: NEONNIGHT34609
I agree, but I consider the tach to be non-critical so I went the easy route.
Kevin
Jesse_81
Sep 17, 2014 04:20 PM
acebogey
Apr 16, 2012 10:21 PM
sporty2003
Feb 12, 2007 03:54 PM
DGlide04
Aug 21, 2006 10:22 PM
kpreese
Mar 21, 2006 05:31 PM
