fxdx front end wobble 80mph+
Old Sep 10, 2010 | 09:09 PM
  #31
Dynaglide68's Avatar
Dynaglide68
If you lowered the rear with Progressive 11" then that's your problem !
Old Sep 10, 2010 | 09:14 PM
  #32
Elginator's Avatar
Elginator
Originally Posted by DXrider
...They say if it wobbles in the front its probably from the rear...
+1 on that. A friend of mine had the wobbles on his touring model and the GM of our dealership told him that front end wobbles almost always are cause by a problem with rear alignment or stability.
Old Sep 14, 2010 | 05:53 PM
  #33
jbeeze's Avatar
jbeeze
Stage I
New to the forum, but here's my 2 cents. My '04 FXDX did the same type of wobble, but maybe not as violent. After pulling my hair for a few weeks, I finally found the upper engine mount/brace bolts loose where they bolt into the cylinder behind the horn mount. Tightened bolts. Problem gone, steady as a rock to at least 100. Hope your problem is this simple.
vinzilla
Jun 6, 2016 09:53 PM
first dyna 07
Mar 26, 2015 11:30 PM
lewk
Feb 18, 2013 10:58 PM
msulli
Dec 17, 2012 06:12 PM
pnw_hd_rider
Sep 13, 2011 02:20 AM
