Heel & Toe Shifter
Thanks for the info.
I checked out his thread, and it looks good, but I have a fatbob with forwards, and his design would not work on my bike.
I pmed him and asked just to make sure, so I'll wait to hear back from him.
But I would still like to see the product on offer from twin.
Thanks
Lou
Thanks
I use my heel. Extend my leg out and pull up with the back of my heel. Sometimes my highway peg gets in the way but not enough to get excited about.
One of the things I liked about my old '84 FLHTC was the heel toe shifter and the floorboards. Thought about putting a similar setup on the 'glide but......?? Not so sure 'bout all that. Dunno.
Note: in moving the shifter, I discovered that someone had buggered the spline a bit by forcing the shifter off the shaft w/o first removing it's bolt (which is trapped in a groove in the shaft such that the shifter would not fall off even with a loose bolt). I was able to restore the spline using a file (I just happened to have) made especially for sharpening Japanese saws. The bolt threads had been badly mangled from this ham-handed wrenching as well, so I installed a new grade 6 bolt and lock-washer. Even with the shifter bolt fully-torqued, the clamping feature does not tighten completely snug, as the spline's trying to change "pitch" prevents it, allowing a small amount of looseness; this looseness further exacerbates the longish travel.
