Bassani help
Old Jun 15, 2010 | 08:37 AM
rounder's Avatar
rounder
you can get the heat shields and try that as opposed to the wrap. Or you can double wrap them.
Old Jun 15, 2010 | 08:47 AM
SC-Longhair's Avatar
SC-Longhair
Isn't wrapping the exhaust eventually going to cause a fracture in the metal and the OP will eventually be buying a new exhaust?
I've seen it before and I don't think I would suggest wrapping exhaust, especially if it's anything but a cheap set of drag pipes that are easily replaced.
Old Jun 15, 2010 | 10:51 AM
rounder's Avatar
rounder
He already has them wrapped. Having done so, he probably messed up the finish as it stands, so he should double wrap or maybe heat shields will cover the finish enough and work better. Also he could have simply wrapped without enough overlap and is why he is experiencing the excessive heat he is claiming. One more thing is if the pipes were installed with stock gaskets, this could be a problem as well as bassani pipes are designed to be used with SE flat gaskets and not stock tapered ones.
Old Jun 15, 2010 | 12:58 PM
fripple's Avatar
fripple
I ran the pro streets on my street bob and never had an issue with heat. I also used the regular HD stock gaskets with no issues.
perryross
Apr 12, 2013 03:28 PM
BrianABE
Sep 1, 2011 10:11 AM
usefulshrimp
Aug 13, 2011 07:32 PM
Terry66flh
Shovelhead
Feb 10, 2011 07:40 AM
maryland blackout
Oct 26, 2010 07:57 AM
