05 wide glide tail light bracket removal
Old Jun 17, 2010 | 03:20 PM
bbqbrisket's Avatar
bbqbrisket
That's what I am beginning to think I will have to do and I hope I don't have to remove the bags as well.....what a pain. All for a custom tail light. Even if I do get it installed, I will be wondering if I will get stopped because meet code. I know one guy Virginia who did get stopped with this same light and ended up having to get rid of it.
Old Jun 17, 2010 | 04:03 PM
drstephennix's Avatar
drstephennix
What light is it?
Old Jun 17, 2010 | 04:35 PM
8541hog's Avatar
8541hog
That is the Harley relo kit, and yes you will have to remove everything to get it off, that is why I ditched my factory bracket when I went with saddlebags. You can unplug the wires from the connectors to pull them through the hole.
Are you in VA?
Old Jun 17, 2010 | 05:09 PM
bbqbrisket's Avatar
bbqbrisket
If I have to remove all the crap then I think I will be in over my head and have to PAY some to do or assist. $^*# IT!
I am in northern New jersey.
Here's the light I have only envisioned up to this point.
Old Jun 17, 2010 | 05:15 PM
8541hog's Avatar
8541hog
It is a real easy project, you can make your own setup like I did, which will cost less than that one, just a possibility. I posted a how to on my web site about it with wiring diagram.
I can walk you through it if you want.
Old Jun 17, 2010 | 05:48 PM
bbqbrisket's Avatar
bbqbrisket
I will consider that Hog.
thanks
Old Jun 28, 2023 | 01:24 PM
03BLKDWG's Avatar
03BLKDWG
Stage I
I have a 03 DWG and like you said, the fastener is embedded in the plastic tail light and license plate bracket flange inside of the fender. I cannot get either to come loose and there just no way to get a hold of it to keep it from spinning. I am about to use a dermal tool to cut the fastener from the plastic, remove the bracket, then I should be able to get a hold of it. I will replace it with a regular nut and washer over the bracket flange. I have spent most the morning cussing the HD engineers., Good luck everyone.
Old Jul 1, 2023 | 03:51 PM
Geoff's Avatar
Geoff
Don’t cut the plastic. Use a Dremel with a cutting wheel to put a notch in the threaded insert that’s spinning. Then hold a screwdriver in the slot while loosening the bolt.
LunaticFringe
Dec 3, 2014 10:01 PM
bbqbrisket
Jun 15, 2010 07:58 PM
bbqbrisket
Jun 5, 2010 02:55 PM
redrubicon2004
Jul 11, 2009 12:42 PM
