PC III questions
Old Aug 23, 2006 | 12:12 AM
NEONNIGHT34609's Avatar
NEONNIGHT34609
Default PC III questions
2006 bob .
just got my PCIII not installed yet but i am lookin though the softwear i installed .. does this boost the rev limiter ? also i only have slipons but all the maps are for A/C and mufflers .. what map should i go with ? thanks
Old Aug 23, 2006 | 12:03 PM
Stanger's Avatar
Stanger
Default RE: PC III questions
Good question. I would go with the stock setting one, 811-01. If you had the A/C kit I might go with one of the others, but for this instance I would go with stock 01 then if you are not planning on getting the A/C which I highly suggest, then after you get whatever add-ons you want on (mechanical, make it go faster parts), then go get the bike dynoed. You will be happy either way. Great product!!
Old Aug 23, 2006 | 09:50 PM
NEONNIGHT34609
i was looking at the stock setting one if its stock what benefits is it giving me ?
Old Aug 23, 2006 | 10:35 PM
jaysonL's Avatar
jaysonL
Let me just say, I know nothing about this F.I. up grade stuff. What exactly is a PCIII. Is it similar to a S.E.R.T. ? Also are any of them on the market worth while with out a dyno run ?
Old Aug 24, 2006 | 11:08 AM
Mascman's Avatar
Mascman
For just the slip-ons, you don't even need the PC.
I would at the least, put on a K&N filter. This will allow you to take advantage of the mufflers.
Without the filter, I guess your only benefit would be a higher rev limit.
I would definitely think about an intake upgrade...that is where you'll notice an improvement in power.
Old Aug 24, 2006 | 11:19 AM
thebestofindica's Avatar
thebestofindica
If you add a K&N filter along with the slip-ons I will say that you should definitely get a remap of some sort. You are taking an already lean condition and by adding slip-ons and filter, the bikes becomes more lean yet. Get a download of some sort to bump up the fuel. Better yet, get a full exhaust, SE a/c and pcIII from fuelmoto.
Old Aug 24, 2006 | 10:36 PM
TOMMAY's Avatar
TOMMAY
In response to your question about the rev limiter. If you have the Stage I download the rev limiter will already be set to 6200. If not,the PCIII can be used to change the rev limit.
If you buy your PCIII from Fuelmoto they will preload a map to your specs and their prices were the lowest I found,plus you get a two yr warranty.
Good Luck
Tom
1morecast
Oct 13, 2013 09:12 PM
bluesmanjesse
Aug 15, 2010 04:39 PM
flyer91
Aug 3, 2010 11:12 AM
christian0632
Jul 20, 2008 01:10 PM
patsac
Nov 11, 2007 05:51 PM
