Alternate auxillary light kit?
Old Jun 19, 2010 | 12:26 PM
kk6pg's Avatar
kk6pg
Its the HD aux kit, along with the HD signal relocation kit.
Trimming the plexi is easy. I drew an arc with a sharpie, drilled a series of small holes over the line, and used a dremel to cut between the holes.
Old Jun 19, 2010 | 02:43 PM
Taddeoeg's Avatar
Taddeoeg
You can also use a jigsaw and a fine tooth blade to cut the shields. That's how I took 2" off the top and then trimmed to bottom to fit tightly around my 7" Fatboy headlight. Since I'm not as precise as I'd like I cleaned up any little irregularities with a sanding drum in the dremel.
Old Jun 19, 2010 | 02:48 PM
Royce's Avatar
Royce
She looks sharp, been thinking of adding the same set up. The first time that I saw it was on a XL1200 Low. I was surprised how good it looked on a Sporty; looks even better on a Dyna!
Old Jun 19, 2010 | 04:00 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's how it look on my FXD 2003:
kryingame
Oct 11, 2018 08:59 PM
Merk68
Jun 19, 2013 09:17 AM
rhaneski
Aug 7, 2007 07:49 PM
tizone
Jun 16, 2007 01:59 PM
pauletich
Feb 6, 2007 08:01 PM
