Stainless bolts for primary/motor
Old Jun 22, 2010 | 06:56 AM
VA Biker's Avatar
VA Biker
Default Stainless bolts for primary/motor
Im sick of looking at the cheap looking hardware on my primary and motor. Is there a stainless hardware kit for it or do you have to just buy them individually?
Old Jun 22, 2010 | 07:12 AM
cactusred's Avatar
cactusred
Living on the gulf coast, I've got the same concern or problem so I've been replacing a majority of my fasteners with stainless hardware. Your primary hardware is 1/4 inch and two different lengths. Some are 4 inches and the others, I can't remember, but they are shorter. Your best bet is go into a ACE hardware or marine type store, and they carry a large selection of stainless/chrome allen head/torx type fasteners.
If you just can't find em in a brick n mortar store, then you can order em online from say,
Fastenal.com
Old Jun 22, 2010 | 07:59 AM
dyna rider's Avatar
dyna rider
Default Polished Stainless
www.depss.com
Old Jun 22, 2010 | 08:01 AM
VsTheWorld's Avatar
VsTheWorld
http://www.mcmaster.com/#
they've got everything known to man pretty much - so if you have a parts manual you can make a list of all the fasteners you need and buy them all online before having to remove any to get sizes etc. fast shipping too
Old Jun 22, 2010 | 08:07 AM
wolfman 66's Avatar
wolfman 66
Alloyboltz.com sets made for your bike.
Old Jun 22, 2010 | 09:07 AM
stewbeezer's Avatar
stewbeezer
Here is another place: http://toplinefasteners.com/motorcycles.html. They also sell on ebay where you can submit a best offer.
Old Jun 22, 2010 | 09:20 AM
JRK5892's Avatar
JRK5892
ebay has some nice kits but you can also just hit up ace
Old Jun 22, 2010 | 01:11 PM
bklynbob's Avatar
bklynbob
Default grat stuff
Originally Posted by dyna rider
Just don't forget to use anti- seize on ALL s/s hardware.
Old Jun 22, 2010 | 01:31 PM
fhansen's Avatar
fhansen
Stainless steel bolts come in different tensile strengths. I picked some up at a hardware store the other day and was told they were 130,000 psi tensile-very strong. And they were definitely hard. They were shoulder bolts that we had to extend the threads on and were quite difficult to run a die on. You can ask about the TS and should be able to find out.
Old Jun 22, 2010 | 08:04 PM
bigdawgz28's Avatar
bigdawgz28
6th Gear
I bought a kit on ebay from a seller named cyclebolts for 62 bucks..they look far better then stock..
This set includes the polished stainless fasteners and washers for the Lifter blocks,Trans side cover, Trans top cover, Trans side door, Cam cover, Timing cover, Primary cover, Derby cover, Rocker boxes, Speed sensor, Crank position sensor, Coil cover, Oil filler and Electric box.
