Dry rot
Old Jun 25, 2010 | 06:47 AM
essentialcycle's Avatar
essentialcycle
Default Dry rot
So I ordered new intake gaskets since I figured out that they were leaking. Ordered thru a local dealer. Not a bad price. Looked up some instruction on youtube just for a guide. Marked and pulled the intake off. Those flanges are a bitch to get off! But were those gaskets dry! Replaced them, lined everything up and tightened. Now for a test run. When I fired it up it even sounded diffrent. So hopefully my popping sound will go away mostly. Thank's for all the help here so far in the forums. You guys are a great help!
Old Jun 25, 2010 | 08:57 AM
essentialcycle
Well, the popping is still there. Also seems to load up a little. I did put a 185 main in it. It smells alot like gas when at an idle. Might go to a 180 and leave it from there. I suppose a dealer is gonna be my best bet to get this figured out? Some guys tell me it's all the pipes making this happen.
Old Jun 25, 2010 | 01:48 PM
rounder's Avatar
rounder
Put the baffles back in? Also the 185 main is too large go back to a 180 or the 176 you had before. Don't forget the popping can also be increased by exhaust leaks as well.
eddie31770
Jun 5, 2015 01:08 PM
XL1200C/C
May 19, 2007 01:30 PM
asuperheat
Aug 29, 2006 10:13 PM
ralphmalph
Aug 13, 2006 10:33 PM
Nickwg
Exhaust System Topics
May 8, 2006 12:52 PM
