Need help, dreaded electrical issue...
Old Jul 2, 2010 | 07:55 PM
TDSnowSPR's Avatar
TDSnowSPR
So i replaced the battery and checked the PC for water...Took it out and it happened again. I am awaiting a new PC from fuel moto.....hopefully this will fix my issues!
Old Jul 2, 2010 | 10:17 PM
roofer's Avatar
roofer
You say it has 16" apes are they internally wired if so you could have a wire shorting out in there.
Old Jul 2, 2010 | 10:20 PM
TDSnowSPR's Avatar
TDSnowSPR
If the new PC doesn't fix it, that is what I will tackle next!!!!
Old Jul 2, 2010 | 10:58 PM
NoLongerAmember's Avatar
NoLongerAmember
Did you take the PC out of the system and check how it runs without it? You might want to wiggle/tug the wires that come out of the bars while it is running, they should exit down by the risers and see if it acts up, same with the injector wires, wiggle them while it is running.
CB
Old Jul 6, 2010 | 11:11 PM
TDSnowSPR's Avatar
TDSnowSPR
just a brief update......Thanks a ton to Jamie and Keith at Fuel Moto. They were a huge help today helping me get things sorted out....
I put a new PC III in today and the bike was revving very high....right around 2,000 rpms! it would idle up and down on its own. The folks at Fuel Moto talked me through a few things, and we were able to figure out that it is not the PC III. The bike briefly threw a code, but then the light went out. I am going to bring it to the shop and have it plugged in and see what the heck the issue is.....
Thanks again to all who chimed in....Ill update as soon as I get it figured out.
Sean
Old Jul 6, 2010 | 11:43 PM
NoLongerAmember
Sean
Hold down the speedo function button, click the run/stop switch to run and turn on the ignition. diag should appear press the button once and psspt should appear and the P should flash, press and hold the button again until you get a Pcode or None. Post the code.
CB
Old Jul 6, 2010 | 11:53 PM
TDSnowSPR's Avatar
TDSnowSPR
CB
Thanks,
will do tomorrow
Old Jul 7, 2010 | 12:08 PM
TDSnowSPR's Avatar
TDSnowSPR
P0505 and P1004
These are the codes that popped up.
Thanks
Thanks,
will do tomorrow
Old Jul 7, 2010 | 02:41 PM
Airborne350G's Avatar
Airborne350G
P0505 and P1004
Thanks
P1004 = Lost idle speed
P1004 = Current System Relay Contacts Closed
AS for what to look for you got me...
Old Jul 10, 2010 | 04:24 PM
TDSnowSPR's Avatar
TDSnowSPR
Well,
Thanks folks for all of the info!!!! We reset the codes, and they have not come back.....We found the problem to be a short in the on/off switch!!!!!!!!!!!!!!!!!
So far so good!
Thanks again everyone,
TD
