Shock Bolt sheared again !
Old Jul 12, 2010 | 11:39 AM
  #71
arkieollie's Avatar
arkieollie
I pulled mine off years ago and put a grade 8 chrome ones in. Never a problem and they look better.
Old Jul 12, 2010 | 02:05 PM
  #72
CRF's Avatar
CRF
Originally Posted by Wonkaboy
Makes sense in what your saying , if it happens one more time than i'm going back to my stock Harley ones because i never had a problem with stock ones on any of my 6 Harley's and the ride was fine i just like the look of the lowered shock 11" 412's .. , if i ever win the lottery i will buy yours ...
I'm running the stock harley 12"ers on 1" lowering blocks. Best of both worlds IMO; plus it can go back to stock height in about 5 minutes. Might be sumthn to think about if your problem persists with the Progressives..........
Old Jul 12, 2010 | 03:58 PM
  #73
Taddeoeg's Avatar
Taddeoeg
Originally Posted by Charlie [Mortis421]
My left side top section of my shock snapped off ... bolt snapped IN the frame as well... does anyone have the part numbers for the top shock mount bolts and acorn nuts?
Preload setting recommendations for the stock shocks?
Buddy of mine @ Ironcycles in Jamesburg NJ said in 20 years of wrenching he's never seen that happen.
Don't know about the 06 and my 07 uses a stud, but the 00 FXDL my gf rides uses these part numbers:
54557-90 Bolt, shock mount
54327-00 Bolt, shock mount (FXDX only)
7845 Locknut (inner side)
7068 lockwasher (inner side)
6113 Washer (both inner and outer side) Uses two on each shock on the outer side, one on each side of the 54708-65A or 54709-00 (FXDX only) Cover, shock bolt
7554 Acorn nut
Hope this is what you need
Old Jul 12, 2010 | 04:08 PM
  #74
Wonkaboy's Avatar
Wonkaboy
So far so good for me with the grade 8 bolts and i also adjusted the preload to #4 and no more bottoming out , #5 was to stiff.....
Old Jul 12, 2010 | 11:09 PM
  #75
Charlie [Mortis421]'s Avatar
Charlie [Mortis421]
7554 Acorn nut
Thanks Brother! I'll add those to the text file for my flash drive.. If I go the stud set up,. I'm sure that may do it!!
I opened a case with HDCorporate this morning ... the agent tells me "Oh, there is an issue for the 06-07 Dynas. There is a "repair kit" you can have your local dealer order... Part number 49764-06"
So I call my local dealer (HD of Ocean County NJ) ... they tell me they can't order the part it doesn't exist.
But rep @ the local shop told me he'd call corporate (with my case #), and get to the bottom of it.
I'm sure he's a man of his word. Time will tell.
Old Jul 14, 2010 | 09:23 PM
  #76
Charlie [Mortis421]
So I heard from my local dealer today... Apparently the "repair kit" you can have your local dealer order... Part number 49764-06 is in fact a JIG that they have to borrow from the HD folks in corporate... to get this ... ream out, and prep the frame for BIGGER Upper Bolts that replace the OEM ones. This is a known issue with the 06~07 Dynas, so the Rep Rebecca told me.
Once I get more info... I'll post it.
The saga continues...
Old Jul 19, 2010 | 10:06 PM
  #77
Charlie [Mortis421]
Thumbs up Double W00t!! [COVERED]
My Local shop advised me they are covering the claim as a manufacturing defect!!.. (Injectors are going to be an emissions claim) so Double w00t!
Awaiting parts, and green light to get bike to shop.
I'm ITCHING TO RIDE!! Gonna have to kill three tanks of gas just to get this out of my system.. and my OL wonders why I want to take a ride to Virginia to see my friends for a night or three... UGH!
Old Aug 10, 2010 | 09:05 PM
  #78
Charlie [Mortis421]
Thumbs up Fixed and covered!!!
Yep you heard it right from here... My local dealership completed the repairs yesterday, and I picked up my Dyna this AM.
Parts List per the receipt:
(Qty 1) 54517-06 Shock Absorber
(Qty 2) 54666-08 Stub, Shock MNT
(Qty 1) 54716-06 Spacer, Upper Shock, RH
(Qty 2) 6792 Washer, Hardened, .90 OD
(Qty 4) 7880 NUT, HEX [entered twice as 2 items]
Some items on list not sure exactly why:
(Qty 1) 68664-06A STALK, Turn Signal
(Qty 1) 73102-96BK TAB Housing, 2-Position
(Qty 3) 73191-96 Recepticle, Contact, 20-1
Work Description:
SHOCK RECALL DONE
P/N 54666-08
LC:2488 (Job Code, listed under Labor)
Also installed (2) 27709-06A Injectors under different work order (FREE)
Old Aug 10, 2010 | 09:31 PM
  #79
HDTech74's Avatar
HDTech74
if I'm not mistaken the injectors they installed are 25 degree
the old ones were 8 degree I believe.
Old Aug 11, 2010 | 12:38 AM
  #80
thealaskan's Avatar
thealaskan
Originally Posted by bigmikaele
grade 8. Pull the other one and bring with you to the hardware store. Match and go.
Best response here. You might break your back on bad roads or **** for shocks, but you are not going to break a grade 8 bolt.
