Flush mount taillight?
Old Jun 27, 2010 | 10:32 PM
mikeault's Avatar
mikeault
HD Dyna, is that solid metal or a plastic with a chrome layer? I'm not a big fan of shiny, so if it's solid I could scotch-brite it and make it look brushed. Or do you know if it comes in black?
I like the custom dynamics led strip, I'm just worried it'll come out looking cheap. And for the ~$200 I'll put into it, that's a bit of a gamble because I can't really picture the finished product.
I run a LED bulb from "---'s workshop" (can't think of the name of it) behind a smoke lens. Since the LED doesn't produce as much heat as the incandescent (sp) I could probably get away with the low profile kury huh? I think the lens alone is under $10.
Keep the ideas coming. I appreciate the input.
Old Jun 27, 2010 | 10:34 PM
fixxr's Avatar
fixxr
Default Plate
Originally Posted by HDDyna2006
Is that plate holder curved?
Yes it is.It covers the original hole from the stock light.I made a foam seal to keep slop from dripping out from under the plate.
Old Jun 28, 2010 | 07:42 AM
MDStbob's Avatar
MDStbob
who makes that plate holder? exactly what ive been looking for.
Jim
Old Jun 28, 2010 | 08:02 AM
fixxr's Avatar
fixxr
Default Plate mount?
Jim
Two places to get it are Drag Specialties part#2010-0551 and the other is Custom Chrome part#610492
Old Jun 28, 2010 | 10:54 AM
JRK5892's Avatar
JRK5892
get it from dr V twin (forum sponser) that is where i got mine... on mine i added additional LEDS in the LED board so my turn sigs are the break light as well. then powdered it all black
i made a plate that fills in the tail light hold and cut a hole in that and used a rubber gromit to fill the hole and run the wires though
added LEDs to the 2 holes in the circit board and wired them as turn sigs
wiring all buttoned up after i added LED turn sigs
light on
drilling it out
mock up
Old Jun 28, 2010 | 12:35 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The CycleVisions eliminator has everything already done for you. Brake light, signals and license plate holder all in one. I can whatever you need for your project if you want something else as well. Here is a pic of the CV setup.
Old Jun 29, 2010 | 05:31 AM
MDStbob's Avatar
MDStbob
Default CV
Hey Doc how much is that one on that street glide?
Jimmie
Old Jun 29, 2010 | 09:31 AM
rounder's Avatar
rounder
Originally Posted by JoeGrapes
Rounder, I don't see a tail light or licence plate on your bike. Are you not running a tail light? Do you have a side mount plate? Is there a law that says the plate has to be on the left side. It seems I can tuck it in closer on the right.
I smoothed the fender by having the holes welded in. I am running a run brake turn on the rear(like a nightster/wideglide) I have a side mount plate from e-bay,bolts to the shock and sits in tight only about 1/8" away from the belt guard. The license mount is a really nice piece. This is it http://cgi.ebay.com/ebaymotors/SIDE-...ht_1478wt_1165
wiwhitetails
Sep 24, 2017 04:13 AM
houstonhdguy
Nov 4, 2013 08:52 PM
ncbeast
Jan 31, 2009 04:51 PM
bkpa
Jul 15, 2007 07:18 AM
SVFFB
May 26, 2007 05:44 AM
