replacement dyna tank - which fit?
Old Jun 29, 2010 | 02:13 PM
needlevictim's Avatar
needlevictim
Default replacement dyna tank - which fit?
hi i have a 2003 lowrider and want to sell the tanks and fenders, buying a used set to replace them beforehand. i figure i can make some money back on the custom paint job they have, as i want to spray the used ones satin black and use them anyway.
im looking for a replacement tank but can it be any dyna tank, or does it have to be from a certain model to fit my bike. I know the lowrider has different gauges and tank strip but does this affect the actual tank im looking for.
thanks
Old Jun 30, 2010 | 10:35 PM
fixxr's Avatar
fixxr
It's best to get the same tank,the newer one's are FI and are made with large holes for the fuel pumps. some of the older ones will work but you may not be able to use your dash panel.
Old Jul 1, 2010 | 03:46 AM
grbrown's Avatar
grbrown
How determined are you? I am in the process of fitting a 2009 tank to my 1990 Glide. So far it is not proving difficult. An EFI tank can be converted to carb using a Pingel adapter kit and fuel valve.
Old Jul 1, 2010 | 09:28 AM
U-234's Avatar
U-234
Check out this thread. I didn't get much info on tanks earlier than '04. This question gets asked alot. I think it would be useful to many owners to have a complete list and make it a sticky.
https://www.hdforums.com/forum/dyna-...treet-bob.html
Old Jul 1, 2010 | 02:59 PM
icufltrn's Avatar
icufltrn
The low rider tank from 96-03 is becoming the holy graille of hd tanks, look on ebay and they go for quite a bit esp in good condition. The bracket that holds the speedo and tach to the dash is now "obsolete" and very difficult to find. I think you can have anytanks form those years will bolt up it's just getting all the parts to make the conversion. I went from super glide tank to lr. If you go with sg then you will have to find where you will mount your tach and speedo then get the sg gas guage. The wg has the bigger speedo and no tach. I have heard someone makes an adapter to fit the smaller lr speedo in the wg dash.
Old Jul 20, 2010 | 04:25 PM
needlevictim
well i was only thinkin of makin a little cash on sellin the paintjob i have, as im sure someone else would enjoy it more than me, but if its this much hassle then i quit. im just gona paint my own tins. ive just bought a softail rear fender but thats another story
Old Mar 21, 2021 | 10:31 PM
sebastien1993's Avatar
sebastien1993
Stage II
i would like to known more about this im trying to do the same 09fxdl tank to 99fxdx
Old Mar 21, 2021 | 10:32 PM
sebastien1993
Stage II
id like to know more about how you did it. im in the process of doing one with a 09 fxdl tank
Garbonso
Jun 10, 2017 12:44 AM
Garbonso
General Topics/Tech Tips
Jun 9, 2017 04:30 AM
TuilkWG12
Dec 3, 2012 11:05 PM
TexasNewfy
Jun 10, 2010 05:42 AM
98fxd
Exhaust System Topics
Aug 23, 2005 12:44 PM
