Riser Bolt Size And Length
Old Jul 7, 2010 | 12:47 PM
8541hog's Avatar
8541hog
That's the goofy name, why not call them riser bolts.....
I think on my apes I ran them up to 55 to eliminate the play in the bars, but that was a few years ago.
Old Jul 7, 2010 | 04:06 PM
BlockHead96's Avatar
BlockHead96
Just finished putting the spacers in, look good and height feels a lot better, along with some gained pullback. I just hand tightened the bolts (cranked on them) as a torque wrench I have won't clear the headlamp! What I did notice was, I have much more flex now in the bars because of the risers creating more leverage, therefore, more bar movement. I'm going to try it as is, in theory it should help with some vibration.
Old Jul 7, 2010 | 04:17 PM
8541hog's Avatar
8541hog
I have never tried spacers, how do they work? Does the riser bolt go all the way through them, or is it a 2 bolt deal, one in the riser, one in the spacer?
Old Jul 7, 2010 | 04:43 PM
BlockHead96
Just had to replace the two bolts with 2" longer ones. yes, it's just a 2" spacer with a 1/2" thru- hole. No other bolts, just the ones on the bottom of the upper tree.
http://www.spacerjim.com/LowRider2.JPG
Old Jul 7, 2010 | 04:53 PM
8541hog's Avatar
8541hog
Rubber or poly bushings? Poly should allow you to snug those up more and take the play out.
Old Jul 7, 2010 | 05:17 PM
confederate's Avatar
confederate
Most Wanted
Curious as to why you're not changing the rubber bushings to urethane bushings??? I did when I installed my risers and they do make a difference.
Old Jul 7, 2010 | 06:33 PM
BlockHead96
I retained the stock rubber for now, I want to see how it effects steering and handling, if at all. If I feel it's to much play or slop in the bars, then out they go! I want to see if I feel any vibration differences.
REW13
Nov 1, 2017 08:53 PM
Jersey Drew
Apr 4, 2016 08:58 PM
tbone4760
Apr 26, 2015 11:49 AM
OldTyme
Aug 10, 2012 03:47 PM
Milty
Apr 18, 2009 01:58 PM
