Front End Wobble on two up trip....Darn
Old Jul 9, 2010 | 09:25 AM
ggadwa's Avatar
ggadwa
Default Front End Wobble on two up trip....Darn
I'm sure this has been addressed numerous times in the past. I'm just bummed that on the 700+ mile two up trip with the wife this week...The Scoot had front in Wobble in the curves.....It has never done this before. Checked the tire pressures both spot on. Maybe it was the load the scooter was carrying but the confounding thing is we've hauled mostly identical load before......I did do the front Motor Mount skim change like many others last fall.
Any experiences with the front end wobble showing up....when it hasn't been there before???? Solution??? True TracK???? or????
GARY
Old Jul 9, 2010 | 09:31 AM
lo-rider's Avatar
lo-rider
Default search
Try a search; there are currently open threads.
Old Jul 9, 2010 | 10:32 AM
8541hog's Avatar
8541hog
I had this happen the first time I rode with my tourpak setup, had to move the tourpak forward an inch to transfer weight forward, just that little move made a difference. Just had too much weight on the rear with all our gear riding 2up. Check your weight distribution and see if you can adjust it in anyway.
Old Jul 9, 2010 | 10:53 AM
jaxdwg's Avatar
jaxdwg
GARY
This may sound strange but when I went on the Kyle Petty charity ride in 05 my bike got to being unstable and I thought the steering head bearings were going out but it turned out that the small suitcase I had tied on the seat was tetering while riding, causing the problem. I found out when I took it off to carry a second person and all the wobble went away. After that I tied the suitcase down tight and had no more problems. Perhaps something on the back was not tied down tight enough.
Old Jul 9, 2010 | 10:57 AM
grbrown's Avatar
grbrown
GARY
What do you mean when you say the tyre pressures were 'spot on'? When 2-up the pressures in the owners manual are not enough IMHO. To get decent ride and handling when riding fully loaded on tour (with my Glide) I use 44F/50R in my Avon Venoms, solo 38F/44R. I don't ride my Dyna 2-up.
If your tyres are under pressure you may well get a wobble in some conditions. Could be as simple as adding say 4psi both ends.
dpoll995
Feb 26, 2017 05:01 PM
Slvr764
Apr 3, 2013 09:39 PM
Time2Cruise
Sep 27, 2010 12:24 PM
oley55
Jul 26, 2010 07:57 PM
trever.thompson
Apr 20, 2008 05:52 PM
