Why not Screamin Eagle
Old Aug 27, 2006 | 07:54 PM
FXDLBill's Avatar
FXDLBill
Default Why not Screamin Eagle
What is the story? I have seen many many posts bashing Screamin Eagle parts/builds. Is it the quality, price, sour grapes, what?!!!! Shouldn't the performance division of HD have the best parts and know the most about how to get the most from their own engines? I am not defending SE, I just would like to know is anybody satisfied with their Screamin Eagle builds? I have a opotunity to have my bike upgraded thru the dealer at a great discount using SE parts. Should I or should I not do it? TC 95 Stage IV TQ Carureted or HTCC Stage II Carbureted for under $3600 complete (including local sales tax)
Old Aug 27, 2006 | 08:06 PM
voyager1's Avatar
voyager1
Default RE: Why not Screamin Eagle
my opinion, screaming eagle makes great stuff .
Old Aug 27, 2006 | 08:54 PM
pococj's Avatar
pococj
Just an observation: If HD was the only outfit that knew how to get the goodies outta their own engines, S&S woulda been outta business decades ago. There's an advertiser on here that can do a 98" conversion on your motor that'll probably be less expensive than the HD 95 kit, plus it'll pump out more ponies, to boot. And I just read about a massage-job on a stock 88" motor that pushed the 100/100 numbers. So, like most everything else in life, ya chooses what suits ya, and ya pays the price.
Old Aug 27, 2006 | 10:07 PM
FXDLBill's Avatar
FXDLBill
I'm not saying that SE is or should be the only. Just want to see what all the bashing is about.
The 98 CI kit is more expensive if you factor in a new cab and ignition system, labor & tuning (I no longer have time to do major wrenching). But it looks mighty tempting!!!!!!!!!!!
Old Aug 27, 2006 | 10:20 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Screamin Eagle parts are very good quality from Harley Davidson. There is the problem. Even though they are considered "High Performance" parts some of them still fall under EPA regulations since Harley produces them. Harley's heads are very good quality but not near as opened up as high performance heads from independant dealers like S & S and the people who are porting and polishing them. Heads are probably the most important part of a build besides the proper cams. I have a 95" Screamin Eagle engine on my 2000 SE Roadglide and without a lot of extra work it wasn't all that fast.
Old Aug 27, 2006 | 10:35 PM
SPECIAL ED's Avatar
SPECIAL ED
(snip)And I just read about a massage-job on a stock 88" motor that pushed the 100/100 numbers.
You have my attention.Please enlighten me.
Old Aug 27, 2006 | 11:17 PM
redheadfred's Avatar
redheadfred
same here ! I need to know more about this 100 hp build on the 88
Old Aug 27, 2006 | 11:27 PM
FXDLBill's Avatar
FXDLBill
The factory made special edition SE models are 100% under EPA regulation. The SE upgrade parts are not (at least not to my knowlege).
Old Aug 28, 2006 | 03:18 AM
Z's Avatar
Z
I chose Edelbrock heads over SEs for my Evo because, although their flow volume is lower, they have higher flow velocity in the RPM band wher I want to operate. From what I understand, this yields more power than the higher flow volume / lower flow velocity SE heads. From what I understand, ported stock heads also out-perform SE heads for all but high RPM applications where flow volume becomes a bigger issue. If you want all-out, top-end performance go with SE. Otherwise look to other solutions. That's my understanding, anyway.
Old Aug 28, 2006 | 10:38 AM
jkenosh's Avatar
jkenosh
i installed a screaming eagle 211 cam in my stock 2006 88 and it really woke it up, but it says on the box for off-road use only not emissions legal,
