how long will factory black engine finish last?
alex
Take a look.
[IMG]local://upfiles/17261/31BF45AE564E4DB4B8BFC9224A132B50.jpg[/IMG]
[IMG]local://upfiles/17261/332150102324452E968969158485F372.jpg[/IMG]
[IMG]local://upfiles/17261/5BDA7D93B7DE419C80D0948805EE8F7D.jpg[/IMG]
<âWgSkeeâ>
<âcj_slowdown... Your info is correct as I know it to be...â>
My answer is just the way I know about, most likely there are 10âs of more ways, he has done this appox. 20 years and I canât argue against it, I see that it works.
<â In other posts I mentioned that I painted a few of my engines BBQ Black or High Heat Black after I burned the paint in I'd hit it with WD-40 never blistered or flaked...â>
I am sure it that it works since you have done it, I like WD-40 on some things, the one thing I donât like about it is, I believe it leaves a film ?
<âI don't want to start a debate.. â>
Why not : - ) itâs one way to get a lot more ideas on a subject from different people, I think itâs better to speak up and either add too or challenge a subject, we can only learn more from all kinds of riders w/more ideas.
<â But, it's been said a black engine will dissipate the heat more efficiently... as long as it's not more than 5 mils thick.â>
Iâve heard that also, then in later years they added in âpowered coatingâ, that to me must add heat, I mean itâs plastic !
As far as black engines go, I think HD makes the best painted ones out there, my first FXS had it, it doesnât look that good now, maybe if I did what Bill did to his engine, it would look a lot better ?
But painted engines from HD that doesnât make it ok w/engine heat retention as I mention in that post, S&S doesnât paint there engines at all, only the jugs, (and they are powered coated ?) in fact on their web site or their catalog (I canât remember which) they even said about painting their engines black âNo, donât ask, we donâtâ , Whats that, about ?
WgSkee, lets hope others add to this topic, I think we would like to know more ways of keeping them clean and looking good over the long haul.
Take care,
cj
I guess this would be a good starting point.. the cooling benefit at speed is by convection, but, while seating in traffic, the heat would be dissipated by radiation better..an Oil cooler, I'm sure is better... But, the black paint looks.. (err..pun intended)...COOL...
A black object radiates heat at all frequencies of the electromagnetic
spectrum if it is hotter than its surroundings (black body radiation).
Other colors radiate in a more limited spectrum. Thus black objects
radiate more heat.
However, in our engines, heat is mostly dissipated by convection (air
moving over it) rather than by radiation. I don't have any figures, but
I would suspect that heat dissipation by radiation is a very small
fraction of total heat dissipation, especially if there is significant
air movement over the engine.
Also, this site has info on the old flatties and the black paint they used back then and restorers still do... The Old ones still do it for me...LOL http://www.flatheadpower.com/US/Flat...erFrameSet.htm
<âA black object radiates heat at all frequencies of the electromagnetic
radiate more heat.â>
As in letting heat go ? you must be right, after all black macadam driveways melt snow/ice faster than concrete, and silver coated roofs donât absorb sun heat as the black ones seen to do.
<âHowever, in our, engines heat is mostly dissipated by convection (air
air movement over the engine. â>
<âAlso, this site has info on the old flatties and the black paint they used back then and restorers still do... The Old ones still do it for me...LOL â>
Yeah, nice to look at, rather ride a little bit newer one : - )
BTW- the site shows the knuckle cyls, black are the split halfs painted ? couldnât really tell, as I said S&S doesnât paint the engine cases or halfs whatever engine your looking at, and that still bugs me : - )
Do you know why that is ?
cj
So much for adding a pic under my sign in name, on left : - ))))
