1994 Dyna Ouestions
Old Jul 23, 2010 | 09:15 PM
CKS's Avatar
CKS
Default 1994 Dyna Ouestions
Can someone tell me or show me with pics which plug is the oil drain & which is the trans drain plug. Also is the allen plug on the side of the trans where you pour the oil in it?
Old Jul 23, 2010 | 11:36 PM
RF99Dyna's Avatar
RF99Dyna
If you want the exact answer, look into a service manual.
I'm not sure how it is on your bike but i have a 99 dyna and the trans plug is under the pan. The oil plug is in front of the pan, parallel to the ground (right behind the cross member on the frame) and to put new oil in, i pull the dipstick and pour it in there.
Old Jul 23, 2010 | 11:46 PM
bikerlaw's Avatar
bikerlaw
The front plug is the oil and the rear plug is the tranny. PA-LEASE!!!!!...be advised, the 90's Evo Dyna's have the worst oil pans/tanks in history. You CANNOT crank the oil plug tight. You only snug it up. If you even try to tighten it like you would any other vehicle from a toyota car to a Shovelhead, you'll strip that plug. Its a god awful design. If you have a spare O-ring, you should change that as well.
The allen plug on the tranny is to fill the tranny and the oil dipstick is to fill the motor oil.
Old Jul 24, 2010 | 05:51 AM
Vern1's Avatar
Vern1
Greetings,
Folks, this post is a good example of how you are supposed to be: Help a fellow biker.
Some forums I visit, the first thing they spout is: Buy the freeking manual you moron....
I will second the motion on the drain threads....mine stripped and I had to install a first oversized drain plug from the auto supply.
Old Jul 24, 2010 | 08:22 AM
CKS's Avatar
CKS
Wow a manual - I never would have thought of that.
bikerlaw - Thanks for the help.
vern1 - You are so right.
Old Jul 24, 2010 | 04:30 PM
RF99Dyna's Avatar
RF99Dyna
you wanna quote the rest of what i said where i tried to give you some input?
Old Jul 25, 2010 | 12:11 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Where were you before I stripped mine. Hahaha Got a new oil pan though.
Definitely change the "O" ring gasket - will help to ensure little to no leaking / drips.
2013superglideseattle
Jul 19, 2017 08:26 PM
PhatBoyHigh
Nov 25, 2015 11:11 AM
aces&8s
EVO
11
Sep 8, 2013 09:43 AM
jakeots
Jul 13, 2009 09:09 PM
harleydom55
Oil Archive (no new posts)
Aug 11, 2008 05:09 PM
