Rush Slip-ons
Old Jul 24, 2010 | 09:44 PM
KDavis's Avatar
KDavis
Default Rush Slip-ons
I am running a set of Rush slip-ons on my 09 SG. They have the 2" baffles. I noticed I had the option of removing the rear baffles. Other than making it louder, will I loose power due to reduced back pressure. Also would it potentially cause other problems? I have the stock air breather and no stage one kit.
Old Jul 24, 2010 | 10:12 PM
joflewbyu2's Avatar
joflewbyu2
I read that 1.75 are the best baffle for stock and intake mods. You need some back pressure otherwise you lose bottom end performance where you ride most of the time.
Old Jul 24, 2010 | 11:58 PM
ColdCase's Avatar
ColdCase
I'm not sure what you mean by rear baffles, there is one baffle in the slip on.
Removing the baffle will probably make it sound obnoxious.
HD exhausts are so short they are all bad, putting free flow exhaust on makes them worse, maybe noticeable. Did you notice the changes from these slip ons? Removing the baffles will make them flow more air, helps high rpm horsepower but hurts bottom end, maybe you'll notice maybe not. It won't hurt anything.
You can get a lot of it back with a decent tune.
Old Jul 25, 2010 | 04:04 AM
SC-Longhair's Avatar
SC-Longhair
Yes your low end power will suck. Don't remove them.
Old Jul 25, 2010 | 08:25 AM
HBomb74's Avatar
HBomb74
how do the rush slip ons sound?
Old Jul 25, 2010 | 04:07 PM
KDavis's Avatar
KDavis
Default Rush
Thanks for the help--and yes they sound good. Had them on a Sportster also-sounded a little better on the Sportster for some reason.
alienbogey
May 19, 2015 07:01 PM
bdtaylor1979
Sep 11, 2014 06:44 AM
Darkrider1695
Aug 3, 2013 10:33 AM
Kojax
Aug 19, 2010 12:00 AM
HARDCAYSEN
Exhaust System Topics
Sep 1, 2008 06:10 PM
