Caution Dyna owners
Old Aug 16, 2010 | 02:51 PM
lo-rider's Avatar
lo-rider
Default Caution Dyna owners
Was servicing my (stock) air cleaner as part of the 10,000-mile service. Found there was no gasket under the filter element. Dealer had provided only the gasket which goes under the base-plate. The owners manual does not show any filter gasket, but has a note to install base-plate gasket. The service manual however does show a filter gasket, and says to replace it.
Called Moco Customer Service. First tech said there was no filter gasket. After I pointed out there was an actual photo of a gasket (and instructions to replace) in the service manual, a second tech then said there WAS a gasket, #29313-95.
Close examination showed some fine grit on the surface of the bore of the intake module. And the oil was very black when changed @ 10,000-miles. The filter element was really loaded w/ dirt, plus some bees, leaves,...
Note: These filter elements are simply washed w/ lukewarm water and mild detergent, then dried. I realize only now that I should not have waited til 10,000-miles to service it. Previous owner (said he) did the 5,000-mile service (and he is a professional mechanic). I took ownership @ 6,600 miles.
So I'm posting to give a heads-up to those of you who perform your own service--be sure to get that gasket.
Old Aug 16, 2010 | 02:59 PM
THPSRIDER's Avatar
THPSRIDER
Good heads up!
Old Aug 16, 2010 | 03:25 PM
gstanley's Avatar
gstanley
Thanks
Old Aug 16, 2010 | 08:52 PM
goblin127's Avatar
goblin127
Thats very good imfo. thanks for sharing.
Old Aug 17, 2010 | 02:03 AM
bullpupp12's Avatar
bullpupp12
i thought the stock filter was a use and replace element? the se element is a clean and reuse. thanks for the info. i'll check mine today
Old Aug 18, 2010 | 06:51 PM
my2dogs's Avatar
my2dogs
thank you sir
Old Aug 21, 2010 | 02:42 PM
Legion Rider's Avatar
Legion Rider
Thanks for the info.
Old Aug 21, 2010 | 04:21 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
10,000 miles? I clean mine every 3-5000
Old Aug 21, 2010 | 06:01 PM
lo-rider's Avatar
lo-rider
Default 5,000 miles
Previous owner did the 1,000 & 5,000-mile services. I got it @ 6600 miles, cleaned it @ the 10,000-mile mark.
SemperRah
Jan 24, 2017 12:16 PM
JONNIEROCK
Jul 28, 2014 09:09 AM
ralfareno
Oil Archive (no new posts)
16
Feb 14, 2008 10:48 PM
anubisss
Sep 4, 2007 03:37 PM
Psycho
Aug 11, 2006 12:36 AM
