brake caliper
Old Aug 22, 2010 | 08:19 AM
spaceblue's Avatar
spaceblue
I have to agree, if you have 1/4 inch of movement something is drastically wrong. Have any close up photos of the unit? Just a suggestion but maybe that would show something obvious to someone here.
Old Aug 22, 2010 | 08:32 AM
cmonster's Avatar
cmonster
looking at the caliper its the left slider bolt. i pulled it out yesterday[10mm 12point socket fyi]everything that the parts fiche shows is in there,bushing-rubber sleeve-it almost looks like its designed to have some clearance between bolt and bushing and float on rubber sleeve- new one on me! oh yeah up and down is prob 1/8 not 1/4 as stated before
Old Aug 22, 2010 | 08:34 AM
8541hog's Avatar
8541hog
Originally Posted by cmonster
looking at the caliper its the left slider bolt. i pulled it out yesterday[10mm 12point socket fyi]everything that the parts fiche shows is in there,bushing-rubber sleeve-it almost looks like its designed to have some clearance between bolt and bushing and float on rubber sleeve new one on me!
Can you post the parts diagram, having a hard time picturing it.
Old Aug 22, 2010 | 08:36 AM
spaceblue's Avatar
spaceblue
Yeah thats what it does. but your only movement should be the flex in that rubber, and that ain't much. Where's the 1/8 inch coming from?
Old Aug 22, 2010 | 09:45 AM
cmonster's Avatar
cmonster
I think possibly the xtra movement is coming from space between bushing and caliper.guess its time to take it to the stealer,its got 3 years warranty left
Old Aug 22, 2010 | 10:21 AM
sniper77's Avatar
sniper77
Too bad you can't post a pic so we could see what you are talking about.
Old Aug 22, 2010 | 12:44 PM
cmonster's Avatar
cmonster
ill try to get a pic up later-time for meds and a nap!be glad when i can actually ride again !!!!!
Old Aug 22, 2010 | 02:38 PM
spaceblue's Avatar
spaceblue
Is that Comfortability Numb I hear playing in the background?
Old Aug 22, 2010 | 04:37 PM
sniper77's Avatar
sniper77
Shhhhh! You're showing our age....
Old Nov 30, 2010 | 10:23 PM
Nods's Avatar
Nods
Stage II
Angry
Hey cmonster .. did you find the issue with this.. I have same issue.. no doubt I've done something wrong on reassembling back wheel.. I've done a tyre change.. yeah we spell it tyre in Australia, and I have the same movement in my caliper as you've described, no heat prob as far as I know, as I've not really ridden it, as I was checking my install, I noticed .. this movement.. Have you found the problem ? If so, would be good to find your results. Hey, hope your back pain, is better.. I know first hand.. what that is like .. after a crushed a vertebra (in car wreck)... Ochies....
RidemyEVO
EVO
26
Apr 3, 2012 09:57 PM
wiegs
Nov 3, 2008 09:43 PM
BluBob
Jul 10, 2008 12:02 AM
Old Texas Gringo
Feb 25, 2008 04:50 PM
TowJam
Nov 4, 2005 06:40 PM
