Need help ASAP
Old Aug 22, 2010 | 07:55 PM
Ronp42's Avatar
Ronp42
Account Retired
Default Need help ASAP
Hey guy's I'm over from the Touring Forum. Got a friend who flew in from Hawaii and rented a Fat Boy Low to ride with my wife and I for two days. today we rode the Dragon, CheroHala Skyway and a few other places. Her bike developed a shimmy or wobble after she get's above 40 MPH. She notices it when she get's off the throttle and it smooth's out when it drops below 40 MPH. I checked for a lost wheel weight, not that! I also felt the wheel bearing's after she stopped and they are not even warm to the touch. Any help will be greatly appreciated. Thanks!
Old Aug 22, 2010 | 08:00 PM
jcmusic's Avatar
jcmusic
Take a look at the front motor mount!!! See if the rubber mount is broken or came loose, or if the studs came out or loose.
Jay
Old Aug 22, 2010 | 08:15 PM
Ronp42's Avatar
Ronp42
Account Retired
Thanks Jay, will check it first thing in the morning!
Old Aug 22, 2010 | 09:14 PM
tincup64's Avatar
tincup64
may sound silly, but sometimes not so technical things are worth looking for also. i would check to see if any rocks/ pebbles are stuck in the tread and obviously check air pressure.
Old Aug 22, 2010 | 09:21 PM
m i k e's Avatar
m i k e
how did you feel the bearings?
Old Aug 22, 2010 | 09:48 PM
Ronp42's Avatar
Ronp42
Account Retired
The bearings were not hot. Will check the rocks/pebbles...and air pressure. Thanks!
Old Aug 22, 2010 | 10:16 PM
Ronp42's Avatar
Ronp42
Account Retired
Air pressure a little low. It had 30 lbs, I put 40 in the tire. I'll take it out tomorrow and see how it feels. No pebbles found, but looking with a flashlight, so will check that again tomorrow morning. Thanks for all the help.
Old Aug 23, 2010 | 12:44 AM
EricInNCa's Avatar
EricInNCa
Did you post this in the Softail forum too? Fat Boy Lo guys are probably in that section...
Old Aug 23, 2010 | 12:53 AM
rounder's Avatar
rounder
a fatboy low is a softail not a Dyna. The 30 psi of pressure is probably the correct air pressure as indicated on the frame of the bike(not 40 psi)... Have you thought to contact the people your renting the bike from??? ignore jcmusic's post as the fatboy does not have a rubber mounted engine.
Old Aug 23, 2010 | 09:30 PM
TN-Triker's Avatar
TN-Triker
Sorry for posting this in the Dyna section. The air pressure was too low. I put 38 PSI in and the wobble disapeared. Thanks to everybody's input. We rode close to 700 miles in two days. Had a blast! She's taking some good memories back to Hawaii.
