Clanking when I hit bumps
Old Aug 23, 2010 | 07:56 AM
DMV11982's Avatar
DMV11982
It very well may be the tank bolts. I will check them when I get home! I did just get back from a pretty long trip, could have vibrated them loose a bit.
As far as "ridiculing" people for thier lack of diagnostic skills, which none of you have done by the way. I think it is ridiculous. That is part of what these forums are for. I have only been riding for about a year and a half now. No way I would know to check the tank bolts..thats what you fine folks are here for!
Thanks, I will check back later tonight and let you know if this solves the issue!
Old Aug 23, 2010 | 08:49 AM
PigInaBlanket's Avatar
PigInaBlanket
I had a clanking problem but it turned out to be the rubber kickstand bumper. It kept moving on me and would make the kickstand hit the frame. It is easy to check. If you put the kickstand up it should sound like a soft thud of metal hitting rubber.
I finally had to replace mine when the rubber split. So far the new one is staying in place.
Old Aug 23, 2010 | 09:03 AM
Foodog's Avatar
Foodog
Had two different dealer "techs?" tell me the clanking noise was normal for a dyna and that they all had noisy front ends. Three more techs at an indy shop rode it around but couldn't pinpoint where the noise was coming from but pretty much agreed it wasn't normal. On a whim I took off the seat and whaddya know, there was no bolt in the rear tank mount. Bought a bolt, tightened it down and the front end suddenly lost the clank and has been nice and quiet ever since.
Old Aug 23, 2010 | 10:06 AM
gt46660's Avatar
gt46660
X10 on gas tank bolts. had the same type of noise. I have a tank lift on and they had lossened up abit.
Old Aug 23, 2010 | 12:51 PM
Robert Le Gras's Avatar
Robert Le Gras
In June I took a 3500 mile or so trip, the last 830 mile or so day was done with hours going 80 and more. . . . The next day there was that clank. Was the tank bolt.
Old Aug 23, 2010 | 03:53 PM
DMV11982's Avatar
DMV11982
Sure enough, that is what it was. Thanks guys.
Old Aug 23, 2010 | 04:34 PM
clicker01's Avatar
clicker01
ATTN: Forum members! We have another satisfied customer! The trip to Hawaii is still in play, so keep up the great work.
Naw, there's no trip to Hawaii... but still, good job!
Old Aug 23, 2010 | 04:41 PM
JRK5892's Avatar
JRK5892
any idea where it is coming from? front back middle left right? that will help us to give you an idea of what has rattled loose off our scoots
Old Aug 23, 2010 | 04:51 PM
clicker01's Avatar
clicker01
It was his tank Joe.
Old Aug 23, 2010 | 06:07 PM
PigInaBlanket
That's what I love about this forum, it helps you find little aggravating problems and fix them easily.
