Clanking when I hit bumps
Old Aug 22, 2010 | 09:35 PM
DMV11982's Avatar
DMV11982
Default Clanking when I hit bumps
About a week ago, I started noticing a little clanking noise when I hit bumps. It does not happen every single bump I hit. There is no set speed it happens at either. It is weird, sometimes I hit huge bumps and nothing, sometimes small bumps and I hear it. It is very intermittent. Any ideas?
Old Aug 22, 2010 | 09:44 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Try these things:
1. tighten gas tank bolts front & rear
2. Check upper motor mount where it bolts to the engine
3. Re-torque your steering head nut.
4. Check jiffy stand to make sure it is resting on the rubber stop when in up position and not hitting frame.
Old Aug 22, 2010 | 09:49 PM
DeathProof72's Avatar
DeathProof72
I had a similar problem myself on my 09 FXDB. Felt it a bit on my left footpeg. Check the distance from the bottom of your engine to the frame as compared with another bike. Mine was riding too close, which turned out to be a bad front engine mount. Hope this helps...
Old Aug 22, 2010 | 09:54 PM
bberck's Avatar
bberck
Its most likely the tank bolts. I just had to retighten mine the other day as it was doing the same thing.
Old Aug 22, 2010 | 10:03 PM
wideglidebob's Avatar
wideglidebob
check your diet
Old Aug 22, 2010 | 10:09 PM
CKS's Avatar
CKS
Mine was doing that & it was the jiffy stand. Put a piece of rubber on the frame & it went away.
Old Aug 22, 2010 | 10:13 PM
clicker01's Avatar
clicker01
There was a guy who posted here that he was disgusted with his bike and wanted to sell it because it made him feel sick just looking at it. He took it to the dealer to diagnose and repair a clunking noise he picked up while riding to a location on business. Fuel tank bolts were loose and the dealer charged him $50 to tighten a bolt. His bike was still on factory warranty, but overdue scheduled service. Dealer said it would would have been caught and corrected had he brought it in for scheduled maintenance because it's on the checklist. Dealer wouldn't budge. It wasn't the selling dealer which I'm sure would have made a difference. HDForum members, in all their glory, showed no compassion while ridiculing the OP for his pi$$ poor attitude and apparent lack of diagnostic ability... which is of course true; LOL... check your tank!
To the post above, a rubber stop on the frame is stock. If it's missing, or misaligned, it would definitely cause a clunk, but you should hear it crack every time you raise the stand.
Old Aug 23, 2010 | 02:40 AM
Bear_925's Avatar
Bear_925
yeah sometimes people ridicule too much and im sure we've all sometimes been there, something simple that can easily be fixed, may just need another eye on the bike to find it, maybe even ask a friend around with a bike, hard to tell over the internets.
Old Aug 23, 2010 | 02:54 AM
Tat2u's Avatar
Tat2u
check the "fall-away" adjustment procedure as outlined in your manual and also the tank bolts, they've been the main culprits for this noise
Old Aug 23, 2010 | 05:33 AM
bucket13's Avatar
bucket13
I have the same noise, sounds like it is coming from under my feet. It is annoying but I think it is only the kickstand hitting against the frame.
