Newest Headlight Mod
Old Aug 24, 2010 | 05:31 AM
karlkcfi's Avatar
karlkcfi
I have been wanting to do the same for a different reason(lower my windshield) but now I know it will work and that it looks good too!
Did you have any trouble with the wiring reaching that far forward?
Old Aug 24, 2010 | 05:53 AM
DeathProof72's Avatar
DeathProof72
Not at all actually, it was tight, but there is enough internal slack that I was able to just pull some extra wire out from the opening in the frame.
Old Aug 24, 2010 | 07:57 PM
karlkcfi's Avatar
karlkcfi
Thanks!
Now I just need to decide how far forward and down I want my headlight moved.
Old Aug 24, 2010 | 09:39 PM
DeathProof72
Thanks!
There are 3 very similar mounts with different lengths and drops made by headwinds:
Part # 1-0012
FXSTD Extension Arm
• 1-5/16” forward offset.
• 7/16” drop.
• 2-1/8” long.
• 3/4” thick.
• 3/8-16 holes.
• Available in polished aluminum, chrome or brass plated
Part # 1-0012-1
FXSTC Extension Arm
• 1-5/8” forward offset.
• 7/16” drop.
• 2-7/16” long.
• 3/4” thick.
• 3/8-16 holes.
• Available in polished aluminum, chrome or brass plated.
Part # 1-0012-2 (The one I am using)
Same as 1-0012-1 but extends forward slightly more (not sure of the measurements since this one is not on their site)
I went with this one since the location of the mounting hole on my triple tree is at a location where if the downward bend was not far forward enough, it would not allow the bend to clear the front of the tree...
Bear in mind, the stock bolts will not work since the mount is horizontal and not tapped as deep as OEM at the base (same thread size, just a shorter bolt needed). Also, the part that bolts the headlight, unlike OEM, is threaded and not a passthrough so the stock bolt with a collar will not work, you will need a bolt that is fully threaded. I picked up all the necessary bolts at a local MC shop for under $3, so I wouldn't recommend paying $10 or so for the hardware from Headwinds. All bolts are 3/8-16 thread like OEM though.
Here are 2 pics so you can see how the mount I have fits and works with the wiring with no problem. The wiring looks tight, but the handlebars are in the fully locked position and has enough slack not to tug anywhere and when angled forward does not bunch up..
Old Aug 27, 2010 | 08:30 PM
DeathProof72
Better angle, without spikes...
Old Aug 27, 2010 | 08:46 PM
hdbobber's Avatar
hdbobber
I wanted to get my light out a little more so I made this bracket.
Old Aug 27, 2010 | 11:32 PM
CincyRider's Avatar
CincyRider
Looks good, I was wanting to raise the headlamp like on a springer.
+1 on the goofy look with a QD windshield...why I don't use mine much anymore.
Old Aug 28, 2010 | 06:34 AM
DeathProof72
Nice..
Old Aug 28, 2010 | 07:07 AM
masterblaster's Avatar
masterblaster
Looking to do the same thing, are the triple trees and the mount the same for an 09 FXDC.
Old Aug 28, 2010 | 11:19 AM
DeathProof72
If both bikes have the same stock mounting block, which I believe they do, I would say yes.
Zim
May 6, 2014 04:23 PM
128auto
Jun 21, 2012 12:47 PM
jcmusic
Aug 21, 2009 08:05 PM
soup
Mar 28, 2009 10:42 AM
CLL375
Jun 27, 2007 03:22 PM
