Reflector removal .... 2010 FXDWG
Old Aug 24, 2010 | 08:34 AM
HutchNJ's Avatar
HutchNJ
Question Reflector removal .... 2010 FXDWG
Hi folks,
Have a new 2010 Wide Glide and looking for an easy way to remove that silly reflector hanging off the rear fender. Any ideas would be appreciated.
Thanks
Old Aug 24, 2010 | 08:45 AM
louisianaSVT2001's Avatar
louisianaSVT2001
Removed mine yesterday...Use some fishing line and slide it behind the reflector and steadily pull away
Old Aug 24, 2010 | 08:49 AM
Pagan48's Avatar
Pagan48
Removed the reflectors on mine by squirting a little Goo-B-Gone behind them and then just working them off by hand. Cleaned up with a little windex and good to go. no evidence they were ever there.
Old Aug 24, 2010 | 08:50 AM
Phrogman's Avatar
Phrogman
And then when you're done go over the area with Goo Gone to remove any residue. Also, you can use dental floss if you don't have fishing line.
Old Aug 24, 2010 | 08:55 AM
junior07's Avatar
junior07
There are quit a few ways to do this. And you will find lots of threads on this if you search.
My favorite way is to use a hair dryer to loosen the adhesive and peel it off. If you are patient you can get all of the adhesive off without needing to use any adhesive remover.
By the way, when you are dome with the rear fender, dont forget to get rid of the ones on the forks.
Old Aug 24, 2010 | 09:03 AM
Cowpokey's Avatar
Cowpokey
I've heard dental floss and "goo be gone" also..mine are still in place. Don't know what the laws are here or if they are required equipment in Korea. They don't bother me so they stay...for now.
Old Aug 24, 2010 | 09:28 AM
porker's Avatar
porker
Old Aug 24, 2010 | 10:00 AM
VsTheWorld's Avatar
VsTheWorld
i actually added reflective tape (3m black) - invisible during the day, bright white at night (silly me for trying to be more visible)
but when I put my rigid rack on the stbob I used floss to cut through the foam tape (very easy) and googone for the residue (it won't hurt the paint). Then rubbing alcohol to remove the googone. (I put the red reflectors back on after the rack was installed - can't hurt and don't care if they aren't cool)
Old Aug 24, 2010 | 10:09 AM
DarkHorse88's Avatar
DarkHorse88
When I removed the reflector from the rear of the fender, I simply applied pressure forward, toward the tire and it slowly peeled away; no fishing line, no chemicals. As for the other 4 reflectors, floss or fishing line and some goo gone. Too easy.
Old Aug 24, 2010 | 11:56 AM
PGDredd's Avatar
PGDredd
Exactly! Grab it, slightly push forward, it comes right off.
