Did you change your map ...? If so, look at the documentation for TTS ...? When I changed the map for my T-MAX after swapping cams, I didn't notice the speedometer setting was not the correct one for Dyna ... I had to link to the module and change the input for speedo ... not sure whether it could possibly be a setting on the TTS ...?
Off hand ... not sure what else might be causing it ....
The T-Max has a speedometer calibration programming mode ... not sure if the stock ECM has the same feature (don't have my manual with me) ....
Steps are: enter the speedometer calibration programming mode by turning the ignition power on, while holding the throttle wide open. DO NOT START THE MOTORCYCLE with the throttle fully opened. The Speedometer value will begin to climb if the programming mode is properly activated. The speedometer value (mph) will begin to rise in increments of 10 mph. Release the throttle when your speedometer reaches 20 MPH (for 2006-08 Dynas). The speedometer will freeze on this calibration value when released. To program the new value in the ThunderMax ECM’s memory, simply activate the hazard flashers. After a second or two, the speedometer value will drop back to zero. You are now finished and can de-activate the hazard flashers.
You might check your manual to see if there is a similar procedure or simply give it a try ....
Ok here is my latest checks..
Took gauges off and looked at all connectors. √ all good..
Checked harness around gas tank .. √ all good..
Connection at VSS clean and connected properly ... √..
Speedo flickers when key is turned and lights up.. √..
Odometer is visible and working.. √ ...
Actual speedo moving as i ride ......... X..
Ill keep looking today..
I may remove the VSS and check it for crud.....
1 pm edit :
VSS removed ....all good in there....
Disconnected battery for 30 minutes as well.
Still Nada..
More to follow..............I posted this in the tech section as well.
